  • Guests: 53
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Glued transformer core seperation techniques?
V3rge
Sun Aug 14 2011, 05:53AM Print
V3rge Registered Member #3253 Joined: Wed Sept 29 2010, 12:21AM
I have a bunch of small and larger 'E' core ferrite transformers pulled from various moderate sized power supply's and wish to put my own windings on the bobbins.
What ways are there to seperate the 2 part core without damaging it? Are there heating or solvent methods?
Sun Aug 14 2011, 08:03AM
Heat works, but will damage the bobbins if you are not very very careful.
Soaking the entire transformer in acetone will dissolve the lacquer
AleSeg
Sun Aug 14 2011, 10:45PM
AleSeg Registered Member #2727 Joined: Tue Mar 09 2010, 02:39PM
For me has worked well to place the transformers in a can with water and boil it for 20 minutes. After boiling, many adhesives are released.
Best regards
Mon Aug 15 2011, 12:54AM
Can high heat (As in a small torch on its lowest setting) cause permanent property changes of the ferrite? Is the curie temp significant in cosideration for this purpose?
1313370325 2431 FT1630 Adhesiveremove
I clean my cores of plastic and copper via hack saw and disc samder/grinder, then im left with what you see at the bottom of the next pic, a core which has been epoxied with strong, hard, black stuff. I'd really like to seperate them, i tried using a diamond tile saw, but that eats 0.1 inches of window length due to kerf. It also doesnt leave the faces really flat.
testtest
Mon Aug 15 2011, 01:12AM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
Depends on how the top of the E holds the core or blades. I had great success with a press applied to the edge of the top piece for an assymetric core The varnish just gave way in a clean fashion. Otherwise with intermeshed cores small tapping with a hammer would eventually dislodge the assembly. The varnish is brittle and turns into a fine powder on multiple impacts and shocks. The winding was then just extracted intact. Worked for me several times. Some cases needed a rasor blade as a wedge too. Some others the core just broke..... depends a lot on the construction geometry and the type of glue used. If you do not care about the winding the solutions above may be safer to keep the ferrite parts. Good luck.
Dr. ISOTOP
Mon Aug 15 2011, 03:41AM
Patrick wrote ...
My attempts to heat-gun the cores at 400C yielded several broken cores :(
Mon Aug 15 2011, 03:48AM
bwang wrote ...
Wow. That really sux.
haxor5354
Mon Aug 15 2011, 04:24AM
boiling water sounds like a good idea, might try it tmr
Forty
Mon Aug 15 2011, 05:11AM
boiling in water or soaking in acetone will also leave you with reusable wire and bobbins.
Mon Aug 15 2011, 05:13AM
I value the ferrite way more than the bobbin or copper.
