  • Guests: 36
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Car Troubles
Chip Fixes
Thu Aug 11 2011, 12:12AM Print
I have a 94 Plymouth Acclaim and today the right turn signal quit working. The left one works fine but when I engage the right one there is no beep and and the flashing arrow stays on along with the front right turn signal light. But that's not all... The right rear brake and turn signal light don't work at all (even when I press the brake), except that when I turn the key to acc both bulbs light up. I checked all the bulbs and fuses but everything is fine in that regard.
I bought the car for $100 and I really don't want to pay someone else to fix it, is there anything I can do?
EDIT: Could it be the relay?
Forty
Thu Aug 11 2011, 03:08AM
I'd check the turn signal switch in the steering column. If the switch and contacts check out there, then it could be a relay. sounds like the continuity to the back is fine since you can get the bulb to light up when you turn the key.
radiotech
Thu Aug 11 2011, 03:28AM
On your 1994 PLYMOUTH ACCLAIM, the FLASHER is:
FRONT SEATING AREA, PASSENGER SIDE, UNDER DASH, MOUNTED BEHIND GLOVE COMPARTMENT
Read more: Link2
Chip Fixes
Thu Aug 11 2011, 04:15AM
Ok thanks guys, I will check out the contacts with the switch first because I have had trouble with that before, and it broke while I was using it.
Chip Fixes
Thu Aug 11 2011, 11:28PM
Ah it turns out it was the bulb! I guess a filament was off or something
