  • Guests: 48
RoV IW3IPD (63)
01/13 si2030 (62)
HV DC Filtering
cduma
Tue Aug 09 2011, 12:43PM Print
What does it take to get a smooth HV DC from a MOT? On the VTTC FAQ it said you would need 10's of uF but, thats a bit impractical at the voltages in use. The reason I want to do this is to audio modulate a VTTC.
Tue Aug 09 2011, 01:04PM
cduma wrote ...
Clearly, this depends on the current required, but in general you would have to use large can HV electrolytics in series. Eight 4700μF 400V electrolytics - each larger than a soft drink can - would give you an effective capacitance of about 600μF @ 3200V, a costly proposition.
Why not use cathode modulation using an audio transformer?
cduma
Tue Aug 09 2011, 01:29PM
From what I have read the 60HZ buzz is very prominent without filtering.
Tue Aug 09 2011, 02:29PM
cduma wrote ...
Prominent is an understatement! smile
This is what half-wave rectification looks like without a smoothing capacitor:
1312900019 543 FT0 Half Wave Rectification
Forty
Tue Aug 09 2011, 05:03PM
how about using a pulse discharge capacitor?
the kind weighted more towards capacitance than voltage. (ie. Link2
would probably be cheaper than lytics that big.
or would they not be suitable for a smoothing application?
Tue Aug 09 2011, 06:52PM
Forty wrote ...
That capacitor would do very nicely if it were not "untested as is" with a "corroded" case and did not cost $200. Someone might themselves decide that they were preapred to take the risk of such a part exploding, or causing a fire, but I would not be the one to recommend anyone to use such a doubtful part at several thousands of volts, when the energy stored in a 460μF capacitor would be almost 1000 joules.
Ash Small
Tue Aug 09 2011, 07:17PM
Proud Mary wrote ...
cduma wrote ...
Can you not build a bridge rectifier from four MO diodes?
This would require a lot less smoothing, it may even be possible to use MO capacitors in parallel for smoothing?
Tue Aug 09 2011, 07:27PM
Ash Small wrote ...
cduma wrote ...
One end of an MOT secondary is Earthed to the laminated core.
Someone here is bound to say that you could un-Earth the cold end of the secondary, and perhaps you could, but the insulation is not designed for that, and no serious person would ever suggest it.
Forty
Tue Aug 09 2011, 07:37PM
oh, no. I didn't mean buy that exact one. i just meant it as an example of the discharge caps that have a higher capacitance versus the types that have maybe 1uF at 25kvdc.
Nah
Tue Aug 09 2011, 09:27PM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
Well, I did it, and it worked fine for me.
Why don't you used a Greinacher circuit? Link2
