  • Guests: 52
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Brush-less DC Motor modifications
Turkey9
Tue Aug 09 2011, 12:56AM Print
Hello!
I'm looking at modifying a computer fan to use the motor out of it. What arrangement of magnets should I use? The motor has four coils so I assume that it's a four pole motor. I'm planning on arranging rectangular neodymium magnets on a ring for the rotor. What would be the best number of magnets to use and how should I arrange the poles? Thank you!
Jesse
Forty
Tue Aug 09 2011, 02:02AM
my name's jesse too! why do you have to disassemble it instead of just using the motor as is?
image : Link2
lots of motor info: Link2
Turkey9
Tue Aug 09 2011, 02:22AM
Wow small world!
Thanks for all the info!
I'm hoping to build a water pump for a computer cooling system. Having a brush-less design will allow me to completely seal the rotor and impeller and prevent any leakage. I was thinking that modifying a fan motor would be the easiest, but looking through the site you provided I think I'll try the type that are used in floppy drives. It looks easy enough to build from scratch.
PSCG
Tue Aug 09 2011, 07:50AM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
You don't need to worry about sealing the motor, i've seen many homebrewers using them as - is to propel underwater robots. The problem is not the sealing, is the corrosion from the fluid that they are sinked.
