  • Guests: 28
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Control of inductive loads by a triac - 'solid state variac'
Marko
Tue Jun 27 2006, 09:49AM Print
PS. fixed broken link.
I recently read ST microelectronic's app note about controol of inductive loads with triacs, without complex logic or special IC's.
(etc. known scopeboy's 'solid state variac')
Their regulator is basically a dimmer, with additional triac (pulse train generator) used for proper triggering of main triac. (there are waveforms shown)
In the end they show some real application schematics, if it works with an arc welder I guessed it could also work for stuff like NST's, MOT's, varying voltage to mains rectifiers and etc.
] 1151401778_89_FT0_triac__inductive_load_ssvariac.p df[/file]
Another (tested) schematic from different source
Bennem
Tue Jun 27 2006, 05:33PM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
I built a similar version of Steve Conners second solid state variac circuit, for my DRSSTC coils.
works great!
1151429594 154 FT12183 Soild State Variac
1151429594 154 FT12183 Dscf0050
Marko
Fri Aug 04 2006, 10:35PM
I did some work on this thing recently;
Circuit works nice, altough it needs some furnishing between C1 and the pot in order to get desired regulation range.
Real test will be controlling an inductive load instead of bulb and scoping the waveforms on various power settings..
1154730914 89 FT12183 P1290003
Waveform looks like this with a lightbulb, on some 20% setting. Noe that negative halfwave owns a bit higher amplitude than upper halfwave. Triac seems to be a bit faster on triggering there, and I'm not sure why yet. Effect corrects itself with higher settings.
Marko
Sat Aug 12 2006, 09:12PM
After assmembled circuit proved to be working I started playing with various loads.
This is secondary voltage of a small 40W, 36VAC transformer. It was important that there were no voltage spkes at any setting (with no load) wich would generally be bad for HV transformers.
1155417151 89 FT12183 40wtran
I also wanted to see how does the circuit cope with a pseudo-capacitive load (rectified mains line). I hooked it up to a computer SMPS; it looks good when lightly loaded, altough a PFC choke in series with input would be a good idea. It could also help limiting inrush current.
I could also use a little more snubbing since waveform got a bit asymetric.
1155417151 89 FT12183 Atxload
Finally I tried to regulate a small 15kV 20mA OBIT and it seems to be working good.
Not as close as 'smooth' like normal variac but it is usable as low-cost dimmer variant.
I could nicely regulate power (and spark length) without side-effects trough entire renge.
1155417151 89 FT12183 Full 1155417151 89 FT12183 50 1155417151 89 FT12183 20
Sat Aug 12 2006, 10:56PM
That's cool Firkragg! The ST circuit with the diac and two triacs seems to do exactly what my two solid-state variac circuits did, but it's much simpler smile
I once saw funny stepped waveforms like the ones you got when driving the SMPS. I think it's caused by the load current being too small to hold the triac on, so it keeps turning off and then getting retriggered by the next pulse from that hard firing network.
1155423408 30 FT12183 Ss Variac Wfm
Marko
Wed Aug 16 2006, 11:57AM
I found hat increasing snubber capacitor value across the triac helps making waveform symetric in most cases. (problem is that this increases leakage current a bit)
One another thing is instability of output; when 10k reisstor heats up (and it gets quite hot) setting 'increases' a little until resistor settles on it's working temperature.
And it's simply unpractical and un-elite to have a ig hot resistor in the circuit.
Improvment could be using a separate power supply (especially if more than one regulators are used) but a little problem would be finding a transformer with 68V secondary :/
I guess something like 40..48V would work nicely, just anything that would be over diac firing voltage.
Wed Aug 16 2006, 01:50PM
What part numbers of triac and diac did you use in the circuit btw? I'd like to try building one here.
I think it would make a good power control for Terry Fritz's SISG system. My plan is that the "bits missing" from the voltage waveform caused by phase angle control will help the SISG to quench enough that I can get rid of the power resistors in Terry's current design. I thought of using my own solid-state variac but it seemed too complicated to fit well with the SISG idea.
Marko
Wed Aug 16 2006, 02:20PM
I used that little red diac from a energy saver bulb. It's a common DB3 diac from ST Link2
Triacs I used were both BTA12-600 triacs because I had a lot of them at hand.
Trigger triac can be any small triac like TLC221 (as shown in AN) or similar.
Instead ov transzorb shown in AN I used two antiparalell zeners and they worked fine.
Most component values probably aren't very critical..
Part Scavenger
Sat Aug 19 2006, 01:45AM
This might be a dumb question, but heck, I don't know the answer. Will the SS variac drive a doubler well? I'd like to use that on my coils, but I don't have 240 everywhere I go.
Marko
Sat Aug 19 2006, 01:56AM
Yes it will drive a doubler, altough peak voltage may differ a bit with setting.
