  • Guests: 38
~50KV from 1 CR123 3V Battery
Hotwired
Sun Aug 07 2011, 04:11AM Print
Hotwired Registered Member #4049 Joined: Sun Aug 07 2011, 03:50AM
If this is not a new design do say.
Essentially it works on the same principle as a stun gun. Except its possible to construct from everyday objects and a couple of cheap mail order components.
1) A tiny oscillator circuit from a disposable flash camera is used to bump up 1.5-3V to 350V
2) A 0.22uf metal foil capacitor is charged to ~350V
3) A spark gap in the form of a gas discharge tube, in series with the capacitor and a HV coil is set to arc at 350V
4) Every time the capacitor hits ~350V the spark gap arcs and pulses the HV coil
How to:
First you need the capacitor charging circuit from a disposable camera. Any will do but the easiest way is to get a Kodak Fun Saver camera. The Wedding and Custom Kodak cameras are the same thing by the way.
Get the battery out of it, and short out the capacitor before removing the circuit:
Camerar
Chop off just that corner with the charging circuit on it :
Circuitsquare
Solder two pins and add four wires to make it usable :
Circuitwired
That's the difficult bit done.
The rest is plug and play. These are what you need :
Assemblym
The spark gap in this example is a 350V gas discharge tube (so it will arc at ~350V). You may also get by with an open air gap as commercial stun guns use which is two strips of metal crossing each other separated by a thin insulator.
To assemble follow the video:
It can be made smaller:
Tmpwu
I'm hoping to get it working with a solid state alternative to the gas discharge tubes such as a MOV or avalanche diode, anyone able to help out with advice in that respect?
Incidentally, although I use the tag of stungun, it has no relevance to its actual use. It was designed and made for flammable gas ignition. In potato guns.
Calling it a stun gun gets more hits than a high voltage spark generator though ^_^
Cheers.
EDIT: Images resized by moderator, read the rules about posting large images in post!
haxor5354
Sun Aug 07 2011, 04:17AM
how long will the discharge tube live?
Hotwired
Sun Aug 07 2011, 04:25AM
I've run this circuit flat out with two fresh AAA batteries for half an hour with no failure. Although as the batteries fade the spark rate does slow.
However the gas discharge tube does eventually fail, starts arcing at a much lower voltage and needs replacing. I can't really give a proper time period for that and doubtless neither can the manufacturer since normal use of these tubes is for surge protection not this lark.
Mind you while it does work it's an excellent and reliable switch for a set voltage.
Sun Aug 07 2011, 04:38AM
Nice demo.
Your pictures are much wider than the forum rules allow
(tho' we'be seen worse).
This is not a bandwidth thing, it's about readability on small
screens. If you use the "attach file" dialog, your post will
get a pretty large "thumbnail" image and clickable link to
the full size image.
Chip Fixes
Sun Aug 07 2011, 04:45AM
have you shocked yourself with it yet? And how did you cut the PCB? I was just wondering
Hotwired
Sun Aug 07 2011, 04:53AM
No and absolutely zero intention of finding out what a shock would be like, probably get quite a few jolts before a reflex could kick in.
The PCB was cut with a dremel using a thin cut off disk, much safer for the circuitry than waving a hacksaw at it.
kimbomba
Sun Aug 07 2011, 04:56AM
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
Can you give more info on the HV coil construction please?
Hotwired
Sun Aug 07 2011, 05:02AM
No I cannot.
Well I can, ish.
Ferrite core with the primary wrapped round that.
Secondary is wrapped on a plastic bobbin with 8 divisions over the ferrite core..
Whole thing is vacuum potted in epoxy.
The HV coil is not home made, it was hacked from a commercial spark generator which used a 9V and a solid state circuit to produce a spark for lighting a BBQ about twice a second.
The idea of the project was to make a driving circuit which could be added to any high voltage coil such as an ignition coil.
Sun Aug 07 2011, 08:00AM
Hmm, I have some similar coils here which I bought online from some shady guy who claimed that they were out of "some sort of igniter"... needless to say I haven't had much luck getting them to work.
I didnt pay that much for them but maybe the problem was lack of voltage- the primary measured less than 1 ohm so can't have been that many turns.
I once made a homemade transformer using one of those electronic gas lighters with the coil and 1.5V AA, by potting the secondary in Araldite.
Even though air bubbles were present it did work and the output voltage before arcover was significantly higher than before.
The commercial transformers are made using a stack of iron laminations covered in fibreglass cladding, with the primary wound around that.
Over the top of the primary goes a second fibreglass cladding, followed by a plastic insert where the secondary coil is pile wound in sections.
Connections come out on opposite sides to reduce stress on the encapsulant, then the whole thing is heated to about 70C and soaked in mixed encapsulant which can be styrene monomer+catalyst, epoxy, etc.
Then the unit is placed under vacuum and ultrasound agitated to release any trapped bubbles within.
My thought is that CCFL transformers aren't that heavy so maybe someone can hack these into HV generators by replacing the primary with a new one wound at right angles to the secondary i.e. across the windings and then vacuum potting the transformer ?
Wonder if when combined with a high voltage diode and 30KV rated 1500pF capacitor (cheap, saw these on ebay for under £2 each) you could make a Lifter power supply?
-A
Alex M
Fri Aug 12 2011, 03:15PM
Awesome!
BTW what camera did you use?
