  • Guests: 49
RoV IW3IPD (63)
01/13 si2030 (62)
800kV DC for power transmission? what?!?
haxor5354
Sat Aug 06 2011, 10:53PM Print
just saw this video form Siemens Link2
apparently they're trying to transmit power over long distances with 800kV of DC.
can't imagine how they generate 800kV DC then invert them back to AC to feed the grid.
and whats wrong with power transmission using AC anyways?
seems like the "war of currents" is not over yet
Sat Aug 06 2011, 11:11PM
A challanger has appered!
2Btesla
Tesla uses wireless energy
It has little effect
in all seriousness i realy wonder where this may take us in the future?
Dr. ISOTOP
Sun Aug 07 2011, 12:16AM
HVDC is a very desirable way to transmit power; its just the cost prevents it from being prevalent (giant inverter stack -> NOT CHEAP :( )
Inducktion
Sun Aug 07 2011, 01:33AM
I thought AC was better for long distances than DC for some reason.
haxor5354
Sun Aug 07 2011, 01:43AM
Inducktion wrote ...
I think AC generates too much EMF causing more line lost
Adam Munich
Sun Aug 07 2011, 03:50AM
With DC you have no capacitive or inductive losses, so it is actually a better system for transmitting power. The problem with it is the fact that you can't easily change the voltage. Transformers do not work, and making an 800kV DC DC converter... well it ain't cheap.
Sun Aug 07 2011, 04:21AM
HVDC power transmission has been around for decades, even when the rectifiers and inverters used mercury arcs instead of giant thyristors (which are probably the core of Siemens technical advances being promoted). You can learn plenty about it by searching the Internet.
There are, IIRC, three types of installation where HVDC makes economic sense.
1. Long point-to-point links carrying plenty of power -- the capital cost and power losses in converter stations are outweighed by lower capital cost and losses per mile of line.
(among other things, you need only 2 conductors, and the peak voltage for insulation and corona mitigation is 1.0 instead of 1.41 x RMS voltage.) Examples are the Pacific Intertie in western USA, and a major line in Congo between IIRC a big hydro generation plant and a mining/smelting district.
2. Exchanging power between independently synchronized AC grids. For example, North America has four separate grids (not overlapping geographically!), and a number of AC-DC-AC converter facilities on their boundaries.
3. Where power must be transmitted in submarine cables, for example to populated islands, the HV lines have much more capacitance per unit length than overhead lines. With AC, the reactive line-charging current can cause large I2R losses.
Maybe Radiotech can point out my mistakes & omissions.
Sun Aug 07 2011, 01:08PM
or just read here: Link2
Dr. Slack
Sun Aug 07 2011, 08:01PM
That was from way back in Nineteen Hundred and frozen to death, when the only practical way of converting between LowVolts-HighAmps and HighVolts-LowAmps was a transformer, so the only practical way to get long distance transmission, which needed high voltage low current to make copper losses bearable, was to use AC and transformers.
It was sort-of possible back in those days to transform DC up and down, but that meant either a motor-generator set, which was hugely more expensive to both buy and run than a transformer, or very lossy, very fragile things like mercury arc rectifiers. So it was never done for bulk power transmission, tying power stations together for instance, just ona factory by factory basis where it was needed.
In other words, given a vast amount of power to shift, transformers and AC were cheaper, then.
Now the costs are that a DC line with masses of silicon each end is cheaper than a more heavily insulated AC line with transformers at each end. So guess which the world is moving to.
Sun Aug 07 2011, 08:57PM
Japan has a HVDC transmission system through mountain tunnels... 300kV if i remember right.
