  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
hamfest
Fri Aug 05 2011, 01:10PM Print
Hi, 4hv
the local hamfest is coming up soon in a few days (UK - poole) what things should i look out for to get?
can you think of any things i should look out for that could be of use?
Things To Look out for ang get:
Oscilliscope
MultiMeter
Capacitor Reader
Inductor Reader
Function Generator
Vacuum Tubes
Variacs
Heatsinks
Component Storage Bins
Large Capacitors
High Voltage Capacitors
Large Transformers
Components
Wire
High Voltage Equipment
Ferrite
Copper Busbar
Things to bring with me:
Multimeter (Checking Variacs)
Screwdriver (Checking Variacs)
Forty
Fri Aug 05 2011, 03:39PM
i hear those can be good places to pick up cheap, large capacitors and hv capacitors.
Fri Aug 05 2011, 05:03PM
il keep my eye out for those too then my bday is on the 9th so il get some money for that too
cduma
Fri Aug 05 2011, 05:36PM
If you want to build a Tube TC then you should find several different model #s of tubes to look for. If you want to buy a variac make sure you bring a multimeter to test for continuity.
Electra
Sat Aug 06 2011, 01:30AM
Be wary when buying test equipment, or any seller using the words “untested”
All too easy to pay money for something you expect to work only to find out it doesn’t.
I seem to be amassing a small pile of oscilloscopes that are probably beyond economical repair / can’t obtain the parts ect.
You will also see some equipment that is so outdated that it’s debatable if it can be of any practical use other than a collectors item.
Components are always worth having, as you cant beat having a good selection around when you want to make something, transistors and IC’s can be tricky unless you are familiar with what the part numbers are.
Oh and if you live with anybody be prepared for the “why on earth did you buy that for?” line when you struggle in with your best bargin of the day.
magnet18
Sat Aug 06 2011, 03:31AM
vacuum pumps are always useful...
Sat Aug 06 2011, 08:23AM
good point!, reccommended price about?
Dr. ISOTOP
Sat Aug 06 2011, 08:53AM
Things I look for:
Class IV lasers
Ferrite toroids
_nice_ test equipment (Fluke multimeters and such)
Weird big things (large pulse caps, etc) that are no fun to ship from Ebay *sigh* I can never seem to find any
Little consumables that are nice to pick up locally
RPN calculators
People who practically give stuff away
Large 'lytics if they are less than $10 and over 4000 uF, or are especially cute (never found one :()
Ash Small
Sat Aug 06 2011, 11:08AM
Tom Williamson wrote ...
Personally, I'd avoid turbo-molecular pumps, unless they are 'guaranteed' and have the controller and connecting lead.
Rotary vane pumps are 'tricky'. I reccomend the older belt drive ones. Edwards are best our side of the pond as you can still get the service kits (Welch are better on the 'other side' of the pond).
Diffusion pumps are good because they are simple, although expect to have to clean it out with acetone or similar and replace the oil. Heater elements 'may' also need replacing. Don't get one that is too big. around two to three inch is sufficient for most 'amateur' stuff.
For either rotary vane or diffusion (you need both for a 'high vacuum' system, I'd say £20 is good if it works, I wouldn't go higher than £50 unless I really needed one and it was guaranteed.
(I did pay £150 for a 'new, unused, still in the box', 2 1/2" water cooled Edwards diff pump last year, though. I've still not used it.)
Maybe others also have their opinions?
Sun Aug 14 2011, 07:43PM
why did it double post :O
