  • Guests: 66
Winding your own ferrite transformer
1 2 3 4  last
Fri Aug 05 2011, 11:01AM Print
Hi, ive been thinking about making my own HVHF transformer,
thing is i dont understand where to start off working out how many turns i need, core size, material
and all the other information, is there anywhere or anyone who can inform me this?
thanks,
Tom .W.
cduma
Fri Aug 05 2011, 11:46AM
I think you should just pick out a medium size torroid and just start winding and see what happens. If you have any sort of design goals I could give a more specific answer.
haxor5354
Fri Aug 05 2011, 12:26PM
start off with 1000 turns on a FBT core and see how many volts you get. put a layer of tape between each layer of windings for more insulation.
Adam Munich
Fri Aug 05 2011, 12:57PM
Link2 Unless you want to meet a design goal just pick a core and wind. Insulation is the hardest part.
Fri Aug 05 2011, 01:05PM
ok
any good reccomended cores? i want to be able to put in about 1 - 3 Kw and how could i go about working out turns per volt?
im looking for somthing simler to Uzzors2k's Big Mofo HV Transformer
EDIT:
also should i run it ZVS or Full bridge?
Fri Aug 05 2011, 03:38PM
Tom Williamson wrote ...
Look at TSC international and others, choose a core with an area you want for the following formula below.
Choose the winding breadth and volume too, based on what you plan to do.
....how could i go about working out turns per volt?
Use the following websites and a calculator.
Link2 (Use this for conversion)
Link2 (Use this for solving Volts per turn)
Im looking for somthing simler to Uzzors2k's Big Mofo HV Transformer
EDIT:
Use a Push-Pull, Half Bridge, or Full Bridge, when your over 1-2kVA. In my oppinion Push-Pull is easiest but has limitations, Full Bridge is best, but expensive and the most difficult of the 3 to get working right. Half Bridge is in the middle.
It appears Uzzors is using a Half Bridge for his big MoFo transformer.
Build a driver that is reliable, then you can swap out transformers as you see fit or burn/explode them.
Fri Aug 05 2011, 04:04PM
Patrick the thing is i dont have a clue about any of this and how to use the calculations and calculator i have absolutely no clue at all im a usual bang stuff together and hope it works guy im trying to acctualy put some scientificness into all this
Fri Aug 05 2011, 04:07PM
Then youll have to learn the math, Precalculus should be suffcient for this task. (if you want to know what is really happening, else you can just guess. Though at 2+kVA, guessing seems dangerous.)
Fri Aug 05 2011, 04:14PM
ok then im gonna go do that,
what design is better: a large pancake coil with centertaps or and single layer winding with center taps?
Fri Aug 05 2011, 04:17PM
learn form the single layer first, later when you gain enough experience you can then move on to radhoo's pancake designs.
1 2 3 4  last
