  • Guests: 29
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
corona discharge - vendor recommendations
John R
Wed Aug 17 2011, 11:51PM Print
John R Registered Member #4058 Joined: Wed Aug 17 2011, 10:14PM
I'm trying to make a setup in my research lab that produces corona discharge. I've thought up some parts I will need, and I was wondering if any of you might be able to recommend good vendors to me for some of the parts.
High voltage power supply - 30 kV, about 50-100 W power
High voltage voltmeter
Microammeter
Thanks!
Adam Munich
Thu Aug 18 2011, 12:18AM
Build it yourself!
A 30kV meter can be made using 600 million ohms of resistance in series with a 50uA meter.
A HV psu can be made by powering a flyback transformer with a ZVS driver. The high voltage can be adjusted by varying the input voltage.
Forty
Thu Aug 18 2011, 12:27AM
are you testing materials with it so accurately that you need to know the exact voltage and current or do you just need corona?
measuring the hv can be done with a normal meter and a voltage divider.
if you can get a flyback transformer like those (non-rectified) then you can probably crank 30kv out of it with one of these Link2
buying a pre-made hv supply like that would be pretty foolish unless you need a fair amount of accuracy in your experiments, so let us know more about your application.
there's always tesla coils cw multipliers too. those can be good at making corona.
John R
Thu Aug 18 2011, 12:42AM
The application is to study the chemistry that takes place when you have corona through a nitrogen/oxygen mixture. I believe we do need a fair amount of accuracy for the sake of reproducibility and reporting.
Adam Munich
Thu Aug 18 2011, 12:45AM
What type of accuracy? +/-1kV is pretty achievable if the currents are very low, as is the case with corona.
Dr. ISOTOP
Thu Aug 18 2011, 12:54AM
If you are trying to measure DC, you can get away with a cheap divider-on-a-stick meter, which can be had from Ebay for ~$20.
Commercial HV supplies are not cheap. If you want to build your own, I suggest a ferrite transformer + a small multiplier + a hard-switched IGBT bridge with PWM to regulate output voltage.
John R
Thu Aug 18 2011, 01:01AM
Grenadier wrote ...
I'm not 100% certain on this. +/- 1kV might be small enough for us, but I can't say for sure right now.
bwang wrote ...
I don't think I'm familiar with divider-on-a-stick meters. Also, do you have recommendations for where to look for some of the other components you mentioned?
jpsmith123
Thu Aug 18 2011, 02:36AM
Will you be working with AC or DC high voltage (or both)?
John R
Thu Aug 18 2011, 02:46AM
For the first stage of the experiment, we were just going to use DC. Eventually it might evolve into a setup that uses AC.
Dr. ISOTOP
Thu Aug 18 2011, 03:02AM
John R wrote ...
Grenadier wrote ...
bwang wrote ...
Divider on a stick: Link2
Literally a voltage divider with a panel meter, on a cute safety stick.
Source your components from Ebay, Digikey, and TSC Ferrite International.
