  • Guests: 48
RickR (18)
TheBoozer (58)
invader (50)
TheAncients (32)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
Parallel Diodes Voltage Drop
cduma
Thu Jul 28 2011, 02:21PM Print
Im doing a high current 12V project and the diodes I am finding have way too high of a voltage drop to be usefull. If I put the diodes in parallel will this half the voltage drop? On a seperate note, would they be able to share the current?
Thu Jul 28 2011, 02:33PM
cduma wrote ...
So called 'current hogging' by one diode often occurs when two or more diodes are connected in parallel. If you connect a resistor in series with each diode, current hogging can be significantly reduced. The value of these series resistors must be calculated to meet the needs of your particular application in terms of current to be passed, acceptable voltage drop, heat to be dissipated, and so on.
Ash Small
Thu Jul 28 2011, 02:56PM
I have found that it is often possible to not use resistors. While current hogging does occur, they tend to share the current more as one heats up, however, there are no guarantees.
If you do try this without resistors, make sure all the diodes are identical and from the same batch.
Thu Jul 28 2011, 03:08PM
Yes the voltage drop decreases, however it probably wont be significant (depends on circuit details). If you put diodes from the same batch on the same heatsink, they will share current well.
Option #2: If the voltage is not too high (below 100-200 volts), consider using Schottky rectifiers.
cduma
Thu Jul 28 2011, 05:21PM
Its 12V at 50A+. The purpose is to use a PSU to keep a charge on a car battery that is powering a stereo.
Thu Jul 28 2011, 05:45PM
cduma wrote ...
Why not buy something like this 100V 50A bridge rectifier, which is not expensive, and would save you from a great deal of needless labour.
Thu Jul 28 2011, 06:08PM
Similar diodes on a common heatsink can be paralleled for higher current because as the datasheet graphs show the I vs V being close to the 'Ideal' diode at low currents but essentially resistive above that.
The intrinsic resistance of rectifier diodes is usually enough for the diodes to 'share' current fairly well.
Your amplifier may be rated at 50A, implying 600W dc input but;
Audio programme material usually has Peak:Average power of 20dB
Wikipedia Link2
So a more modest (1A to 5A) battery charger would probably be acceptable.
The maximum output of automotive audio PAs are usually specified at Vbatt = 13.8
..... alternator output voltage / battery charging voltage.
Unless your power supply can give 13.8 Vdc at full current
(the battery gives nothing above 13V, thus is redundant)
you may not get full rated power output.
So, I think you need either;
A 13.8 V 50A power supply for full power rating
....(no need for a battery)
Or
A 1Adc to 5Adc, 12V battery charger with battery.
Ash Small
Thu Jul 28 2011, 06:11PM
Proud Mary wrote ...
That will need a pretty big heatsink if you push 50 Amps through it, let alone 50+ Amps.
cduma
Thu Jul 28 2011, 08:22PM
Maybe I am going at this the wrong way. I would only need the diode to prevent the battery from backfeeding into the powersupply. Is there another route I could take?
Thu Jul 28 2011, 09:32PM
If your power supply has a rectifier on the output, there is no need to add another diode. Just make sure not to exceed the rating of the output diodes and capacitor(s). (That is, assuming, that it's a conventional power supply with laminated transformer, not a SMPS)
