  • Guests: 42
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
what to do w/ 3 mot sized autotransformers
Forty
Sun Jul 24 2011, 10:32PM Print
just pulled them out of a big enclosure from sort of lighting system.
it contained just the 3 autotransformers and 3 10.5uF 520 vac capacitors.
label information reads:
ballastronix inc.
78-21-1385 BD
120 V
1.90 A hpf
320 OCV 60HZ
Autotransformer
Lamps(1) MH/MV
175W M-57/
H-39 L97
seems to be a 230 to 120 vac step down. can't think of anything to do with them.
Sun Jul 24 2011, 10:34PM
Most likely a high reactance autotransformer ballasts for high pressure lamps, you can use them as ballasts for your projects (either by taking the 320 volt no-load output, or by shorting the outputs and using the primaries in the same fashion as shorted secondary MOTs).
Inducktion
Tue Jul 26 2011, 12:55AM
Auto transformers? Like, variacs?
If they're not that large I might want to buy one if that's okay. PM me if so.
Forty
Tue Jul 26 2011, 01:48AM
no they're not variable, sorry. just a big transformer that uses a single winding. i was gonna look into the cost for shipping them and maybe put them in the junkbox for ~$10+shipping.
