  • Guests: 29
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
call it a stupid idea...but whatever,
Inducktion
Fri Jul 22 2011, 03:28AM Print
My dad recently got this wasp spray stuff....
It said for some reason on the can (probably if wasps tried to make a nest near a power line?) that the dielectric breakdown of the compound was around 41 kv...
I just had an idea, why not soak paper/or create a small chamber of it (let the volatile stuff evaporate?) and use it to make capacitors?
Dr. ISOTOP
Fri Jul 22 2011, 03:31AM
41 kv per what? mil? mm?
Inducktion
Fri Jul 22 2011, 04:43AM
I don't know; I'll have to check tomorrow.
magnet18
Fri Jul 22 2011, 04:55AM
it's flammable, is it not?
Fri Jul 22 2011, 05:06AM
41 kV breakdown on a spray suggests that this rating is for the "cone" of spray coming from it.
Chip Fixes
Fri Jul 22 2011, 05:41AM
magnet18 wrote ...
I doubt it, it's usually only flammable when it's in the can because of the propellant. Although I could be wrong
Inducktion
Fri Jul 22 2011, 05:43PM
That's all the label tells me.
magnet18
Fri Jul 22 2011, 06:15PM
Well, spray some in a bowl and see if it is flammable.
If not, set something up with a flyback or something and see what happens.
vk2fro
Fri Jul 22 2011, 07:27PM
vk2fro Registered Member #3930 Joined: Sun Jun 05 2011, 07:27PM
You'll usually find that some of the flammable propellant remains with the expelled "goods" from the can. Thats why as kids many of us used a hair spray or insect spray can to make a flame thrower of sorts.
Spraying most (except those compressed "air duster" cans) on the ground results in a residue that burns quite readily.
Forty
Fri Jul 22 2011, 08:50PM
as an added bonus, you won't have to worry about hornets nesting in your transformer
