  • Guests: 46
Reaching (40)
ryanshow (38)
07/23 Will (38)
07/23 Arlecchino (41)
07/24 Jim_VE7UV (65)
Tank Fill Valve
Turkey9
Mon Jul 18 2011, 06:34PM Print
I am looking for a fill valve similar to a schrader valve that doesn't have NPT threads. Does anyone know a name for such a valve or anywhere I could search for one? Google yielded nothing but old mustang forums and McMaster only has 1/8 NPT sized ones. A 1/16 NPT schrader would work as well but I can't find any of those either!
I need a schrader valve that has a major diameter of < 3/8 in because I miss interpreted NPT dimensions. I thought 1/4 NPT had a 1/4 in diameter!
Thanks!
doctor electrons
Mon Jul 18 2011, 09:25PM
Asco makes valves. Or Redhat. Not sure if it is exactly what you need but have a look!
Tue Jul 19 2011, 12:17AM
Get a Schrader valve from old inner tube, or parking lot outside a tire-service shop.
Temporarily unscrew the core, then use knife + torch or wire-wheel to remove rubber on the tail end, exposing a bright brass tube. Solder or epoxy that to the fitting of your choice, then re-install the core.
I think the external thread standard (for locknut and/or dirt cap) of 0.305" - 32 tpi was established in 1893.
Turkey9
Tue Jul 19 2011, 01:26AM
That would be a great idea, but I really need to find a valve that I don't have to modify myself. It's not that I don't have to tools to do it; the part will be purchased in bulk in the future.
