  • Guests: 36
marko666 (58)
12/15 marko666 (58)
12/16 Will T (16)
12/16 william L (29)
help needed for a buck converter
1 2 3 4  last
haxor5354
Sun Jul 17 2011, 07:38AM Print
is there a minimum switching frequency required for a buck converter?
I've got a 555 PWM generator that gives me 17kHz at 50% duty cycle.
can I just connect the gate of an IRFP250N straight to the output of the 555 IC or do I need something else so that it fully turns on/of
Sun Jul 17 2011, 09:12AM
There is no lower limit to the switching frequency BUT
as frequency decreases larger values of inductance and capacitance are required, higher frequency = smaller/cheaper.
Also if there is electronic feedback the time constants become longer and the psu loses it's ability to respond to rapid changes in the load.
For a simple buck-converter I'd use a p-channel device as the switch,
you could use an n-channel device as a synchronous rectifier though.
If you use an n-channel transistor you will 'loose' voltage due to the gate-source voltage required.
haxor5354
Sun Jul 17 2011, 03:38PM
ok I followed this schematic
Buck Schematic
and the mosfet get rather hot with a 4 amp load, and yes i did use a heatsink.
so, am I not turning on the gates on properly resulting high on-resistance?
Sun Jul 17 2011, 04:27PM
an IRFP250N starts to turn on with about 4V gate-source voltage,
so if the transistor is connected to the same supply as the 555
the maximum ON voltage at point 'Q' is about
Vin - 4v(irfp250) - 2v(555)
i.e. you 'loose' about 6V, so what you expect to be 12V is only 6V etc.
If you put a p-channel fet in there you would get almost full voltage swing.
haxor5354
Sun Jul 17 2011, 09:15PM
is there a p-channel version of the IRFP250N?
I used this schematic for the PWM generator, but instead of R2 and the NPN BJT I connected the gate directly to pin 3 fo the 555 IC.
Circuit
when I used it to dim a 12v 50W halogen lamp, the mosfet stayed at room temp, even after an hour
sine it didn't heat up I must be driving the gates correctly.
but when I make it a buck converter with the schematic on my previous reply, the mosfet heats up like mad within 2-3 minutes.
whats up with that?
Sun Jul 17 2011, 09:36PM
haxor5354 wrote ...
whats up with that?
Do you have an oscilloscope? we need to definately include or exclude your gate drive conditions as part ofthe problem.
haxor5354
Sun Jul 17 2011, 10:27PM
yup i got a scope
20110717180833931
very quick and dirty
20110717180711248
random inductor + 2 diodes in parallel (1 diode can only handle 3A) + 16v 1650uf cap
20110717180443454
waveform at source
20110717180556705
0.2v ripple voltage at positive side of filter cap?
Sun Jul 17 2011, 10:34PM
measure the voltage at the Gate and Source transistor pins. lets see whats happening.
haxor5354
Sun Jul 17 2011, 10:47PM
10v peak to peak at gate.
6v peak to peak at source.
Sun Jul 17 2011, 11:53PM
haxor5354 wrote ...
Is it a battery powered circuit? can you put the probe ground on the source, and then the tip on the gate?
otherwise i dont know what you mean.
1 2 3 4  last
