  • Guests: 48
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
camcorder viewfinder crt oscilloscope
alf
Sat Jul 16 2011, 11:42AM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hey,
i have the tiny viewfinder crt from an old camcorder, but i dont have the driver circuit board, i wanna make it into an oscilloscope -
what voltage does it use for its heater, and anode? the heater is not 6.3v, it is below 1v i think,
the crt has 6 pins, plus 4 wires for the deflection coils, any ideas as to what those pins are for?
me thinks the heater is the cathode so 2 wires for that, and 4 anodes?
im scared ill burn out the heater, by running it too hot :(
thanks. Alf.
william L
Sat Jul 16 2011, 12:33PM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
I think the heater on all my viewfinders works at 0.6 volts, and the pins are usually heaters accelerating/focussing anodes and a control grid. the one pin that is all by itself connects to the flyback.
alf
Sat Jul 16 2011, 05:33PM
william L wrote ...
thaanks, mine is a sony one, like this Link2 ,
any idea what the anode voltage is?
and, is there a seperate cathode, or is the heater the cathode?
it was showing a dot earlier when i was running it at 2.5v O.o , but now its at 860v, and not even a faint dot, is this voltage too low?
thanks. Alf.
Sat Jul 16 2011, 09:07PM
I have a working one here, IIRC it needs 6V AC.
Some of the earlier ones run at 3V though. If its barely red then thats normal, yellow isn't.
It only has to emit electrons smile
You also need intermediate voltages on the acceleration anodes or the brightness and contrast will be very low- one of these sets the focus.
regards, -A
alf
Mon Jul 18 2011, 06:53PM
Conundrum wrote ...
regards, -A
thanks, what is intermediate voltages? :D
would 1kv do?
thanks. Alf.
Mon Jul 18 2011, 07:22PM
I believe that the focus and screen voltages depend on model but aren't much more than 200V at a microamp.
A simple voltage divider will work here, people have used series connected 150v zeners to get this spot on
See Link2 and Link2
Also Link2 try this with an old camcorder LCD maybe?
PM me and I will see how much the postage is if you want to give this unit a try.
Regards, A
