  • Guests: 15
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
step-up converter problem
hsieh
Wed Jul 13 2011, 02:08PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I want to build something that can charge my cell phone(USB) using a singel cell lipo battery.
I use MC34063.
My schemetic and PCB design was found here Link2
In my circuit, R1 is 910 ohm, R2 is 2.7K ohm ,Ct is 470pF, Co is 2200pF,R is 180ohm,L is 16uH(20 turns of litz wire on CS102060 toroid core,measured with LC meter)
I use a power supply set at 3V as power source.
Without load ,I get 4.8V,But when I connect a 18ohm resistor as load,I only get 3.3V
I tried to connect bigger inductor(200uH),the output rise a little bit, but still less than 4V.
Voltage across pin 1 and GND
1310566038 1412 FT0 Imag0045
1310566038 1412 FT0 Imag0047
1310566038 1412 FT0 Imag0048
hboy007
Wed Jul 13 2011, 03:06PM
Here's what I've got:
Vin = 3.00 ±2% V
Vout = 5.00 V
Iout = 1.00 A
Vripple = 0.05 V
Vin min = 2.94 V
Ton / Toff = 1.01
Ton + Toff = 20.00 µs (micro seconds)
Toff = 9.96 µs (micro seconds)
Ton = 10.04 µs (micro seconds)
Ct = 401.63 pF
Ipk = 4.02 A
Rsc = 0.07 Ω
Lmin = 5.35 µH
Co = 1,807.35 µF
R1 = 0.91 kΩ
R2 = ((Vout - 1.25) / 1.25) * R1 = 2.73 kΩ
modify to obtain suitable parts values. What did you pick for R_sense?
ps. just saw that the calculation spits out invalid peak switch current. Use 0.35A for calculations since the peak switch current rating is 1.5A for one MC34063.
