  • Guests: 54
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Small table-top VTTC
climatex
Sun Jul 10 2011, 05:50PM Print
climatex Registered Member #2012 Joined: Sat Mar 07 2009, 10:22AM
My first ever mini vacuum tube tesla coil, with the PL 500 tube (near equivalent to the PL504, just a smaller anode rating). Pri 16 turns, feed 10, sec 5cm diameter, 10cm long. Anode supply is provided by a two-stage voltage multiplier from the mains. A thyristor staccatto circuit is installed in the cathode, and the circuit has also some fusing to protect both the tube and the cap multiplier /when I was in progress of tuning the coil, eight PL504's failed with a ruptured cathode connection, an arc-over which resulted because of too many feedback turns, had 15-16).
In the constant-wave mode I've got 3.5-4cm free-to-air streamers, 4.5cm to the ground. With the interrupter, six centimeters are achieved free to air and 7 to the ground. Not bad for a 10cm secondary eh? :D
I'd like to thank J. Martiš for inspiration, hints and help he had provided me. /Dr. Kilovolt/
Okay, enough talk, here are the sparks:
