  • Guests: 32
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Choosing a decent soldering iron
Josh
Wed Jul 06 2011, 09:03AM Print
Josh Registered Member #938 Joined: Sat Aug 04 2007, 05:39AM
I've been wanting to finish my microcontroller reef led light for a year or so. I just started it up again and I'm close to being done but my cheap $10 radioshack iron bit the dust.
I've thought about the Hakko 936 however spending $70 on a soldering iron sounds rather high right now.
Is there anything that is high quality but reasonably priced?
Adam Munich
Wed Jul 06 2011, 12:28PM
Elenco SR-1N costs $5 and is just as good as a weller. Just keep the tip clean with a sponge or a brass pad and it'll last forever.
Matt Edwards
Wed Jul 06 2011, 01:28PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Wow, only $5 and just as good as a weller? Hmm...
Anyway, i recently had the same problem and broke down and purchased a weller. Vary happy that i did! However, if you are looking for another cheap iron there is an inexpensive 50w adjustable that i used for a while that works fine (not as good as a weller! But better than a radioshack cheapie). Here is a link.
Link2 (good inexpensive weller 0-850* in 35 seconds)
If you end up purchasing this one send me a PM. I have several spare tips for it that i no longer have use for. In any case, good luck!
teravolt
Wed Jul 06 2011, 02:50PM
hi Josh, this place has lots of different irons I was thinking of getting one for smd removal
ebay is also a good sorce
Josh
Wed Jul 06 2011, 06:41PM
I've been looking at a few brands on ebay.
The VTSS5U are cheap even with shipping out here.
(eBay is awesome)
I might just go for that since I'm not going for heavy use.
However, I've seen the wes51 for a decent price($50 or so),
not far off from the $30 I'd pay for VTSS5U
Matt Edwards
Wed Jul 06 2011, 07:42PM
The wes51 is a great iron. Just something to think about. You could also get a previous model used which i believe is the wes50.
2Spoons
Wed Jul 06 2011, 10:56PM
Save up and buy an OKI PS-900 (used to be Metcal). Best iron i've ever used, and I've used many irons over the years.
Thu Jul 07 2011, 07:51AM
I've been usng Weller irons for about 30 years so I'm biased,
whichever soldering iron you go for, consider;
- Temperature controlled
- 50W minimum
- Buy a small selection of bits,
A very fine bit (1mm) for smd
A medium bit (2 to 3 mm) for through-hole components
A wide short bit (5mm) for groundplanes, rf connectors etc.
- Choose a slim handle, the cheap/fat ones aren't very comfortable
- Must have a stand and sponge
- Don't get thick pvc insulated wire - it's stiff and can be accidentally melted
- Don't get a cheap phase-controller-type as they put out a lot of rfi.
You will also need to do some de-soldering,
a small handheld de-soldering pump and some copper braid
if you don't want to splash out on a de-soldering station ($$$$$)
As a hobbyist you don't need to worry about RoHS etc. so go for lead/tin solder as tin (tin/copper) solder needs a higher temperature and flux.
Although 'nerdy' I recommend protective goggles - any cheap ones.
I wear spectacles and have cleaned tiny specks of solder off many times.
Dr. ISOTOP
Thu Jul 07 2011, 01:03PM
Also, ESD protection (grounded tip) is a plus.
