  • Guests: 49
RoV IW3IPD (63)
01/13 si2030 (62)
homemade capacitors for marx generator?
alf
Sun Jul 03 2011, 11:27AM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hey,
a few days ago i tried making a "capacitor", using a piece of plastic with aluminium foil sticky taped onto it, and i charged it with the flyback transformer, and it discharged with a 1cm spark!
so now im thinking i will make some capacitors to make a marx generator with...
will i need to use 3 dialectrics and 2 plates, if i am to roll the capacitors?
1 dielectric in the middle, a plate on each side, and a dielectric to cover the plates right?
thanks. Alf.
Adam Munich
Sun Jul 03 2011, 12:32PM
Issue with homemade capacitors is they are leaky, and since a marx charges up slowly a lot of power would be lost, maybe to the point where there will be no sparks.
Dr. ISOTOP
Sun Jul 03 2011, 02:59PM
You can always use a high current charger, charging chokes, and triggered firing.
Ash Small
Sun Jul 03 2011, 04:24PM
You only need two sheets of dielectric, but the outer layer of dielectric needs to be longer than the foil, assuming you roll dielectric-foil-dielectric-foil. (Or you can roll extra dielectric, if you only use the same length as foil, plus sufficient to insulate foil to foil, if that makes sense)
EDIT: depending on the former used, you can roll foil on the inside.
Sun Jul 03 2011, 09:31PM
I would say homemade caps are fine. PPE has low losses, and if you dunked the capacitors in oil, it would be even lower. Even PPE copolymer (transparencies) would probably work if in oil. Im not really sure if PPE copolymer is more lossy, but it sure seemed that way when i made caps mistrust
alf
Tue Jul 05 2011, 07:08PM
Arcstarter wrote ...
thanks i shall try it :D
