  • Guests: 42
01/13 si2030 (62)
ZVS Mosfet
Micha0_0
Mon Jun 27 2011, 01:16PM Print
Micha0_0 Registered Member #2990 Joined: Mon Jul 12 2010, 11:22AM
Hey guys
I have built an ZVS flyback driver (Mazzilli Driver). It worked great but yesterday I wanted to put the ZVS in a plastic box with a big heatsink .
After i did this the right mosfet always gets very hot when i draw arcs for some seconds. The left one stays cool.
I think i got a short circuit anywhere.
I measured the zener diodes , the fast diodes and the mosfets , but all seems to be OK .
I really don't know what it could be , so i dont really want to change the mosfet.
Greetings Micha
Mr.Black
Tue Jun 28 2011, 03:59AM
Mr.Black Registered Member #3960 Joined: Mon Jun 20 2011, 06:27AM
I think your driver not have any short circuit
“the right mosfet always gets very hot”
Reason should be On your way to the transformer primary winding imbalance in the fault
so You can check whether your primary balance
Perhaps this is one reason
Micha0_0
Tue Jun 28 2011, 04:50AM
hey , thanks
But I don't think so because finally it worked before i put the zvs in the box .
While this time i never touched my fbt , so it couldnt come from a inbalanced primary but i'll check the windings
haxor5354
Tue Jun 28 2011, 07:04AM
try replacing the mosfet and see what happens?
Micha0_0
Tue Jun 28 2011, 12:47PM
yes I'll replace it
Mr.Black
Wed Jun 29 2011, 11:50AM
If this is the case
i think there may be a diode in the transformer led to its Magnetic field offset
maybe you can try replacing the transformer without a diode
Now
Maybe your transformer's magnetic field is so
Mr.Black
Wed Jun 29 2011, 11:53AM
sorry, the picture in here
1309348380 3960 FT118686
