  • Guests: 50
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
sound activated LED's
Chip Fixes
Mon Jun 27 2011, 04:05AM Print
Sorry in advance if some of my questions are a bit easy, i don't have a lot of experience with led's.
So today I installed a kick a$$ sound system in my car and I thought to myself, "How can I make this listening experience even better?" ... My answer: lighting!
A little while ago i bought 2000 led's for projects Link2 Unfortunately there are not any specs to go along with these so I have no idea what the led's rated voltage/current is. Can anyone help me out? is it pretty much the same for all 3mm red led's?
Lets just say that they are rated for 3v at 20ma, should I wire three led's in series with a 1.5k resistor?
Can I point to point solder or is it a better idea to use prototyping board?
Furthermore, would it be difficult to make them sound activated? I.E. they go along with the music. Anyone know of any good circuits for this?
Adam Munich
Mon Jun 27 2011, 04:55AM
Could make a VU meter out of them. Link2
Mon Jun 27 2011, 06:34PM
It's hard to say what voltage and current they are rated at, the part number does not really give any good results and diffused 3 mm leds range from 1.5 - 2.6 Volt at 15 mA - 30 mA...
Since you have 2000, experiment till you get the light from it that you want, or till it explodes.
lightlinked
Tue Jun 28 2011, 05:28AM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
The wikipedia page for LEDs Link2 has a chart of color to voltage, most indicator LEDs run ~20-30 ma. There are several color/voltage/current charts on the internet, I usually use this book, practical electronics for inventors , as it has one such handy dandy table.
If you want some simple circuits the various Forrest Mims books are a good start. If you want something real fancy, the Arduino seems to have the widest user support base which makes learning easier since there are endless examples of people's projects.
Tue Jun 28 2011, 11:30PM
The old rules of thumb for led voltage worked as the colour was determined by the band gap voltage/energy level.
Modern (Chinese/eBay) leds that I have bought use blue/uv diodes with phosphors, so even a red led can drop typically 3.1v etc.
They also seem more electrically 'fragile'.
