  • Guests: 43
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Depositing BGA balls?
Sun Jun 26 2011, 06:32PM Print
Hi all.
I am looking into using solder balls as a cheaper alternative than trying to deposit solder paste for SMD assembly.
Would a very narrow tube such a syringe needle ground off until flat with a vacuum mechanism work?
Reason is that solder paste is both heinously expensive and has a very well defined use by date after which it deteriorates and stops flowing correctly.
Either that or a way to MAKE solder paste from scratch, it sounds relatively simple.
-A
doctor electrons
Sun Jun 26 2011, 10:35PM
Try one of these!
wink
2Spoons
Sun Jun 26 2011, 10:44PM
Conundrum wrote ...
Really? What sort of paste are you buying? If you keep it capped and in the fridge it will last well beyond the date on the tube.
Carbon_Rod
Sun Jun 26 2011, 11:07PM
These are cheap, but note it is not the same paste used for production.
Ships in 3 to 8 weeks sometimes.
These must be kept refrigerated for the 1 year shelf life, or they only last 4 to 6 months at room temperature.
Ships via next day courier service.
Cheers,
Mon Jun 27 2011, 04:31PM
Cool, thanks.
Presumably freezing it is a bad idea right?
-A
