  • Guests: 70
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Kite lights step-up
TheMerovingian
Sun Jun 26 2011, 10:30AM Print
I'm planning to build some light led lights cheesey for my stunt kites. Those devices will have an on.board DC-dc with duty cicle controlled by a PIC micro 8pin 12series. The main problem that the pic needs 2V to start up and i want to use a single 1.5V battery. It is possible to use the pic at 1.5V @ 4Mhz?
Sun Jun 26 2011, 03:04PM
Why not use a single Lithium cell ?
3.7v, good mAh/weight.
Sun Jun 26 2011, 06:13PM
Joule Thief, connected to zener diode?
Someone else managed to build a microcontroller circuit which generated its own Vcc, bootstrap style.
A lot of disposable cameras use a high gain high current low voltage transistor which can be repurposed for this application, IIRC its a 2SD965.
-A
Sun Jun 26 2011, 06:26PM
Im thinking what sulaiman said, use a lithium cell, i cant think of a reason not to, they come in small sizes.
mikeselectricstuff
Mon Jun 27 2011, 08:27AM
You're going to need more than 1.5v for the LEDs anyway - li.poly will give the best power/weight ratio
radiotech
Mon Jun 27 2011, 09:03AM
Could your stunt kite be fitted with a tiny prop driven PM generator
that would give you ample voltage and current ?
TheMerovingian
Mon Jun 27 2011, 10:29AM
I'm struck in some desing problems. In particular the switching freq is in the range of 200Khz for a 4mhz pic (1 us each instruction), this needs a larger inductor. THe voltage is too low to turn on the pic (only to maintain the ram) so i need to use a 3.6 v lithium, wich turns on the led even at 0% duty cicle (unless i use single switch buck boost). How to bootstrap the voltage for the pic?
Bored Chemist
Mon Jun 27 2011, 06:32PM
"i need to use a 3.6 v lithium, wich turns on the led even at 0% duty cicle"
I don't know about kites, but I think you just solved the energy crisis.
TheMerovingian
Mon Jun 27 2011, 06:58PM
I was saying that the boost topology simply passes the input voltage to the output though the diode so a led will see 3.6-0.7V = 2.9V at his leads and will turn on.. What did you understand?
I will solve it using a buckboost topology using the led as the load.
Mon Jun 27 2011, 07:25PM
If you use a lithium cell
there is no need for any kind of inverter
as both the PIC and the leds can be powered directly
.. what's the problem?
