  • Guests: 61
Busbar material
1 2 3 4  last
Adam Munich
Wed Jun 22 2011, 01:19AM Print
Well I have 12kJ worth of capacitors coming in the mail, and I need to connect them up. So, what are my options for busbars?
Aluminum stock.
Flattened copper pipe.
Wood wrapped in lots of aluminum foil, hey it might just work.
What do you think would be best performance, looks and cost-wise? I plan on making this a 700V cap bank for higher peak currents.
Dr. ISOTOP
Wed Jun 22 2011, 01:23AM
Aluminum is your best bet; it has the lowest price per conductivity.
Ash Small
Wed Jun 22 2011, 01:37AM
Resistance is futile.....look for some scrap copper.
Wed Jun 22 2011, 02:00AM
Do you live near a metal supplier as I do? Id rather use aluminum, as I can get it for a deal as excess scrap, but it depends on your cost/availability, I too have used copper pipe from the hardware store, but its the most expensive way to get copper I think. So i like to use 0.25" x 0.5" rectangular aluminum bar stock for what youre doing.
Adam Munich
Wed Jun 22 2011, 02:01AM
I planned on just going to the local scrapyard and seeing what they have in their alumnium or copper bin. There is likely to be aluminum stock/angle and copper pipe...
radiotech
Wed Jun 22 2011, 06:46AM
What voltage will the bus operate at? High amps can deform buswork
quite nicely.
So will it push apart or squeeze together?
Adam Munich
Wed Jun 22 2011, 12:44PM
I planned on configuring the 'lytics to make a 700V bank for higher currents.
doctor electrons
Wed Jun 22 2011, 09:58PM
Ash Small
Wed Jun 22 2011, 10:29PM
doctor electrons wrote ...
It should be pretty easy to fabricate something similar yourself, using copper pipe, sliced into suitable sections and flattened (annealed if necessary), or whatever is available at the scrapyard. (I was actually thinking of something along these lines before Dr Electrons posted)
ScotchTapeLord
Thu Jun 23 2011, 12:01AM
I recently got the idea to use the aluminum sheets they use to shield the inside of computer towers with. I don't have any conclusive data on its capability (yet) but it's easy to cut with tin snips and you can keep layering it on until you run out of material. A decent size old computer can have quite a bit of this aluminum sheet.
1 2 3 4  last
