  • Guests: 36
vacuum diode
1 2 3 4
cedric
Fri Jun 17 2011, 01:37PM Print
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
hello!
does anyone here have some knowledge about recovery behavior of thermionic diode?
Fri Jun 17 2011, 03:49PM
If you mean the "reverse recovery time", I think it's unmeasurably small on vacuum devices.
Nah
Fri Jun 17 2011, 05:38PM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
It depends widely on the type of tube. any datasheet will show the max frequency. Most of the time it is the the tens of Megahertz. Some tubes work at around 3.2 gigahertz, like early radar tubes.
Fri Jun 17 2011, 07:53PM
Thermionic diode valves do not have any reverse recovery time, because they have nothing to recover from - no charge carrier depletion to be made good and explained away to grieving relatives. smile
Diode valves do, of course, have inter-electrode capacitance, which together with the inductance due to the leads, and anode heat capacity, will determine the useful upper frequency limit of the device.
Mattski
Fri Jun 17 2011, 08:39PM
Proud Mary wrote ...
Really? This is just based purely on my conjecture, but I would expect that when you change the polarity of voltage on the thermionic diode then there is a certain change density of electrons accumulated in the space between electrodes, and so they will flow in the opposite direction for a bit while the field is reversed, until they are all swept out of the inter-electrode space.
Nah
Sat Jun 18 2011, 02:40PM
That's what I was thinking too.
I've never seen a RRT on a tube datasheet, I just assumed that the maker used that number and other factors in the Max freq. time. Well, I learn new things every day here!
hboy007
Sat Jun 18 2011, 10:12PM
for a rectifier tube running at 1kV, 1mA, 1 cm^2 active region, I ended up with an average carrier concentration of 5*10^6 1/cm^3, which is roughly the intrinsic carrier concentration of GaAs and incredibly small (feel free to correct me if I'm wrong). Talking in terms of free electron mobility, I don't think the space charge concentration is an issue (ok, apart from Klystrons and other exotic tubes).
I'm too tired to calculate the time it'll take to deplete the space between A-K but it will be something like the transit time for an electron, like 7.5ns, allowing switching speeds of over 100 MHz. Cheap 1N4148 (trr 4ns) is not impressed wink
Nah
Sun Jun 19 2011, 01:33PM
But there are special tubes that can run at over 3.5 gigahertz.
The hifreq. tubes are usually built in a different maner, and and most of the time smaller in size.
Smaller in size= less capacitance..... = higher frequency
Sun Jun 19 2011, 02:44PM
hboy007 wrote ...
Aren't these things simply properties of the interelectrode capacitance due to the vacuum dielectric, which I mentioned above?
Mattski
Sun Jun 19 2011, 06:50PM
Nope, what I hboy007 and I are talking about is that there are electrons flying between the electrodes when a diode is forward conducting. If the voltage is reversed quickly then those electrons are still there and since there is no recombination mechanism they must be swept in the reverse direction by the reverse voltage to be removed. During this time there should be a reverse current, and the time it takes to sweep those charges away would be the reverse recovery time. You can't treat the vacuum purely as a vacuum dielectric since there are in fact electrons in the dielectric, but capacitance will exist between the electrodes, and I think between the electrodes and space charge.
