  • Guests: 52
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Will this work?
currentkills91
Wed Jun 15 2011, 04:41AM Print
I'm gonna be buying parts for an induction heater, this one here
My question is, is if this high and low side driver is a sufficient replacement for the two drivers in the schematic - IR2110
I wanna try and order everything from one place, and the place i'm ordering from only has that one to offer...
Inducktion
Wed Jun 15 2011, 04:43AM
Generally, I choose not to use hi-low side drivers for mosfets/igbt's, because occasionally they do like to short circuit, then you have your full supply voltage raping your circuitry. Gate Drive transformers give isolation and prevent your brains from going if your brawn decides to blow up on you. Not that anything bad WILL happen, but if it does, it's better to have just one thing blow up than everything blowing up.
If you're still wanting to use a hi-low side driver, I have some from fairchild I could add to your tab. :P
currentkills91
Wed Jun 15 2011, 04:58AM
Hmm...well being new to this whole thing I have not the slightest clue of what else to do O.o
Dr. ISOTOP
Wed Jun 15 2011, 05:34PM
Where are you ordering from?
I suggest the UCC3732x chips (x=1 or 2). 9A is sufficient to drive big FETs, and TI even gives out free samples.
Adam Munich
Wed Jun 15 2011, 10:56PM
Inducktion wrote ...
Just so you know, analog devices makes isolated gate drivers. They pretty much stuck a transformer inside the IC. Link2
Thu Jun 16 2011, 04:17AM
Well problem is that 10ma is probably not enough to drive most power fets.
Adam Munich
Thu Jun 16 2011, 04:32AM
That's why you use an output transistor. Killing a 2n2222 is no big deal, but killing your entire board is no fun.
