  • Guests: 59
RoV IW3IPD (63)
01/13 si2030 (62)
Ferrite Transformer
Mon Jun 13 2011, 08:25PM Print
hello 4hv,
is there anywhere that will show me / teach me from the ground up how to design and build a high voltage ferrite transformer
and chooseing the core ect and how to set it up
thanks,
Tom Williamson
Dr. ISOTOP
Mon Jun 13 2011, 09:54PM
If you want to learn the math and theory, there are assorted resources on the internet for power transformer design, though I don't know of any specifically for HV ferrite.
If you just want a working transformer, Steve Ward's site has a good log of a 3KW ferrite CCPS.
Things to keep in mind:
(1) Make sure to keep your V/turn low enough to keep the core out of saturation.
(2) Make the core large enough to avoid excessive heating (also helps with (1))
With (1) and (2) satisfied, all that remains is to design a secondary properly to avoid flashover; going under oil helps but is messy, potting in paraffin/epoxy works too, as does a properly designed open-air secondary.
ZakWolf
Tue Jun 14 2011, 06:59AM
sorry to hijack, but why make a thread just like this
Hi I was wondering if someone could point me in the right direction for buying a ferrite u core for a flyback, like a website some place where you have ordered before.
Many thanks
Edit: would this work? i haven't looked at all the information on it- Link2
Ash Small
Tue Jun 14 2011, 07:18AM
This link might be useful. Click on 'download':
cedric
Tue Jun 14 2011, 09:18AM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
LittleVenture wrote ...
Many thanks
try this:
Dr. ISOTOP
Tue Jun 14 2011, 11:30AM
Many thanks
TSC is a great place to get ferrite.
FYI they are out of stock at the moment, though frown
Tue Jun 14 2011, 06:48PM
is a ferrite core like this:
______________________
| ___... ___....___...___...|
| |___| |___| |___| |___| |
|_____________________|
1......2.......3.......4........5
possible to work?
1 = Secondary 10Kv
2 = Secondary 10Kv
3 = Primary coil
4 = Secondary 10Kv
5 = Secondary 10Kv
ignore the dots ;D
Ash Small
Tue Jun 14 2011, 09:30PM
Wind the primary under the secondary. use a bigger core.
I've got some of these:
1296115500 3414 FT107217 Cores2
1296107849 3414 FT107217 U Cores
Tue Jun 14 2011, 09:46PM
the specs im after are:
im going to have 7.2Kw in (230v @ 30A)
4 secondaries for series and paralleling depending on what power i want
with 100% efficancy i should get about
18mA per secondary at 10Kv
im probibly wrong somewhere though
im not sure if anything of this is possible im just stepping into the shore of transformer design and building
Dr. ISOTOP
Tue Jun 14 2011, 11:59PM
Having wound (and destroyed) some secondaries lately, i would strongly advise against seriesed secondaries; it increases the stresses on the secondary insulation and just makes everything a pain to manage. For example, i hope you are not thinking about seriesing all 4 secondaries for 40KV out; its just not going to work. It's the old "I want to wind secondaries for 50KV" problem - it turns out that such secondaries are real hard to make...hard to insulate, excessive self-capacitance, etc.
i would use single-layer secondaries with the appropriate step-up ratio. 2 pairs of the large TSC International U-Cores should be good for 7KW; at 100 KHz you might be able to push them to 50V/turn without making them too sad.
What will you be using to drive this thing? 7KW is a lot of power; i would personally not try pushing a bridge of anything other than bricks to this power level; sure it can be done, but its rather finicky. Also, used CM400's are cheap.
You'll need a series resonant topology to ease switching losses.
