  • Guests: 59
response time of a microwave oven transformer?
alf
Thu Jun 09 2011, 07:53PM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hi,
could a MOT respond to 20KHZ?
because a wanna use a triode to drive the flyback transformer, and an MOT as the triodes impedance matching transformer.
thx. Alf.
Forty
Thu Jun 09 2011, 09:14PM
20khz will probably cause greater heating of the iron core. think induction heater. so, it should work, but it will heat up quickly.
HazzWold 1993
Thu Jun 09 2011, 10:45PM
Ive had results using a household lighting dimmer switch in series with a MOC to power a MOT. Can varie the output from blue sparks to firey arcs, because it was restricted to about 600W by my dimmer I felt no noticable heating.
Forty
Thu Jun 09 2011, 11:02PM
yea that would work to vary the output of the transformer, but that's still at 60hz input. a 20khz magnetic field applied to iron causes heating as the dipoles flip back and forth creating intermolecular friction.
