  • Guests: 63
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/04 Sulaiman (71)
12/04 teslarevolution (29)
12/04 AromaZ (69)
First DRSSTC!
Corey
Thu Jun 09 2011, 06:06PM Print
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
Hello all! This will be my first largish Tesla coil so I'm quite excited! Here's the specs:
Primary Coil: 13.8" Diameter, .25" copper tubing, .75" spacing, 5.5 turns
Secondary Coil: 7.8" Diameter, 27.5" length, Fo loaded approx ~70khz
Top-load: Probably going with 6" ducting with 24" outer diameter, wood filler and Alu tape method
Primary Capacitor: CDE caps, 8 strings in parallel two per string(16) for 4kv at .6uf
Switching IGBT: CM300 halfbridge, With 130VAC doubled on the bus prob around 480VDC
Over current set around 600-700Apk
Driver board is by Chris King, May be using "Predikter" like setup for ZC prediction.
Pics:
1307642392 1902 FT0 Img 20110609 133034
1307642392 1902 FT0 Img 20110609 133112
1307642392 1902 FT0 Img 20110609 133128
1307642392 1902 FT0 Img 20110609 133156
Killa-X
Thu Jun 09 2011, 06:32PM
I say good luck, but hey, I got that same exact variac for powering my monster =D Nice. I see you grounded it...Something I have not done my self really. Enjoy your project, sounds fun
Thu Jun 09 2011, 06:33PM
Corey wrote ...
Slighty overcoupled... I might even be saying that it is insanely overcoupled :)
Corey
Thu Jun 09 2011, 06:40PM
Mads Barnkob wrote ...
Corey wrote ...
The base is not yet finished i will be adding a HDPE table tapped in the center with a nylon rod that can be used to adjust coupling, it will be higher perhaps where the last secondary turn meets the top primary turn. As for the variac i believe its a bit overkill, i'd love to know how to pull 20+ Amps from single phase 120VAC outlet... confused
Dr. ISOTOP
Fri Jun 10 2011, 02:54AM
If that's one of those sketchy Chinese variacs it won't be overkill; a 30A Chinese variac will not happily do 30A.
If it is a nice American brand, ignore what I just said.
Corey
Fri Jun 17 2011, 08:44AM
Progress on the half bridge, look good to you guys?
Pics:
1308300136 1902 FT117331 Img 20110616 140123
1308300136 1902 FT117331 Img 20110616 140137
1308300136 1902 FT117331 Img 20110616 140205
1308300136 1902 FT117331 Img 20110616 140441
Shrad
Fri Jun 17 2011, 09:45AM
I should normally get 9 of such capacitors next month (happy)
nice work there! there shouldn't be much inductance either!
Tetris
Sat Jul 23 2011, 09:40PM
I wish I could have an audio modulated coil... my SGTC itself is a failcoil.
