  • Guests: 43
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Reflex battery charger
Mon Jun 06 2011, 09:15AM Print
Hi all.
Probably a stupid question, but why isn't there a device on the market for testing bare Li-Ion cells?
One possible idea is to cross connect two chargers so that battery + charger A discharges into battery + charger B, and a microcontroller logs the results to internal memory.
When cell A is flat B begins charging it until it is nearly full.
Any extra energy needed is drawn from a common DC supply in order to achieve 95% charge.
Seems to make sense, why waste energy into a power resistor etc.
Obviously you would need something like a double changeover relay but it shouldn't be that hard.
-A
Electroholic
Mon Jun 06 2011, 11:08AM
what you typed sounded very confusing to me, but you seem to be thinking about cell balancing. If the answer is yes, then theres this interesting topology called cuk converter. I said its interesting because when it is set up with two series connected cells, the circuit is symmetrical...
Mon Jun 06 2011, 02:02PM
Hmm, this is interesting so thanks for the info.
I will have to look into this, was aware of cell balancing but not that it was done in series.. sounds feasible.
-A
ConKbot of Doom
Tue Jun 07 2011, 01:29PM
The Revolectrix power-lab 8 does regenerative discharging if youre powering it from a 12V (maybe even 24v?) SLA. Charging upto 1.3kW and regenerative discharge is pretty hefty too IIRC. It handles upto 8S balanced Li-Ion packs, and you can hook it up to a PC for data logging. I dont know if their software supports multiple cycles for cell longevity testing etc, but their interface cable is just an optioisolated USB-Serial cable (power, ground and signal from the charger to power the optoisolated side, most likely TTL, but I havent metered/scoped it) So if you want something to do cycle testing then a bit of serial port sniffing might be useful.
Tue Jun 07 2011, 10:54PM
Interesting, though a little expensive for hobbyist use.
Thanks for the info though.
-A
