  • Guests: 17
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
how to build a microwave antenna?
alf
Sun Jun 05 2011, 10:06AM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hi,
i wanna build an antenna for detecting microwaves,
what would be the simplest method for doing this?
i thought 2 wires at the correct wavelength apart, but i dont know
plz help!
thx. Alf.
Madgyver
Sun Jun 05 2011, 10:54AM
Basically yes. The most simple detector is a shottky diode paralleld with a low power LED in reverse, i.e. shottky diode's cathode connected to LED's anode and vice versa. I find Slavas website to be a good source for hobbyist information, although you can only find it in the old archives: Link2
speaking of which, slava once build a detector like the one I just described:
Maybe this two bits of info will give you a clue
radiotech
Sun Jun 05 2011, 06:22PM
There is a design for a plywood microwave antenna. Try
and google for it. I could post a layout if you don't
find it. It was, way before the internet, so it might not
be there.
