  • Guests: 51
10kV photodiode
Adam Munich
Sat Jun 04 2011, 04:17PM Print
I found this today: Link2
It's a 10kV photodiode. I wonder what it costs and what it could be used for...
Pinky's Brain
Sat Jun 04 2011, 11:40PM
It seems to me this is used as a detector, not as a switch. Or in other words you reverse bias it, put it in series with a resistor and shine a light on it and measure the tiny differences in current.
Interesting, but not very useful for the usual endeavours on this forum.
Adam Munich
Sun Jun 05 2011, 12:49AM
How about this:
Series some 1200V IGBTs, and use these along with leds to charge their gates with C cell batteries. Send the signal into the LED and the diode works to level shift the signal, the batteries then charge the gates, (where they would probably last a long time).
10kV IGBTs for the win.
Pinky's Brain
Sun Jun 05 2011, 01:09AM
As I said, it's not a switch ... you could certainly use it to detect light to trigger a driver to turn on/off an IGBT (hard switching IGBT stacks is not a great idea by the way, there is a fair bit of variance in turn on/off time) but you could do that easier and cheaper with a low voltage phototransistor.
Adam Munich
Sun Jun 05 2011, 01:20AM
Meh it was just an idea...
Here's another interesting part, 15kV of isolation between the LED and the diode, but that is something easily beatable just using black shrink tubing and hot glue.
Sun Jun 05 2011, 08:24AM
According to the manufacturer, these opto diodes are intended for use in high voltage switches and remote control circuitry, HV linear regulators, and for the driving of low capacitance loads, such as Pockels cells, and beam deflection plates.
Pinky's Brain
Sun Jun 05 2011, 06:08PM
It's a switch in a sense, but it's a switch which switches a couple 100 uA, that's not going to charge an IGBT gate ... those are not low capacitance.
That said, I never considered that so many devices could use so little current for switching.
Sun Jun 05 2011, 08:34PM
Push-Pull Pockels Cell Driver using 10 kV opto diodes
Source: Voltage Multipliers Inc
I think I might give it a try switching a Low Energy Electron-Impact Photon Source.
Thanks for drawing our attention to it, Adam.
magnet18
Mon Jun 06 2011, 01:05AM
Something like that would be a fantastic way to protect sensitive switching circuitry from back EMF or any spikes or anything.
I wonder if a half bridle circuit could be made using them without too much trouble...
Carl Pugh
Mon Jun 06 2011, 08:48PM
Carl Pugh Registered Member #1064 Joined: Tue Oct 16 2007, 05:04PM
VMI says these application notes explain the use of OZ100SG
Opto-coupler Application Notes
AN-0300 - High Voltage Op-Amp Application Using Opto-Couplers
AN-0200 - OC100HG Push-Pull Driver in Pockels Cells Switching Methods
AN-0100 - Using a VMI Opto-coupler in Conjunction with High Voltage Relays
AN-0000 - General Opto-coupler Notes
How Opto-couplers Work
