  • Guests: 58
My ZVS SMPS
Microwatt
Tue May 17 2011, 04:53AM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
i had finally built this high voltage unit. it runs at exactly 28khz. what can i do to boost the output voltage
1305607991 3282 FT0 000 0001
Adam Munich
Tue May 17 2011, 05:19AM
CW multiplier?
magnet18
Tue May 17 2011, 09:47PM
Marx generator?
Dr. ISOTOP
Tue May 17 2011, 11:01PM
More turns on secondary?
dude_500
Tue May 17 2011, 11:13PM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
Less turns on primary?
Myke
Wed May 18 2011, 01:07AM
The common ZVS flyback driver isn't a SMPS since it doesn't use the same topology. The hack of the current fed Royer driver was designed by Mazzilli hence the other name, Mazzilli flyback driver.
The earlier posts are valid ways of stepping up the voltage though you'd need to rectify the output of the AC flyback to use it to power a Marx generator. If you decide to reduce the number of turns on the primary, the core may be driven into saturation. Also, the higher output voltage would mean more corona which would eat through the insulation reducing the life of the transformer. Putting the transformer under oil might not help since the transformer's insulation isn't meant to stand off that voltage under normal operation.
If you want longer arcs, an increase in voltage isn't going to do all that much. Increasing the current in the arc will allow you to draw the brighter arc out longer. I think the best route would be winding your own transformer and putting that under oil. There are many threads around talking about building high voltage transformers. You don't need to make a pretty bobbin. You could use transparencies or teflon tape to insulate the windings. Make sure the turn to turn potential doesn't get too high which is mostly a problem between the layers. This can be worked around by making pancake sorts of windings.
Others may have more to say about building HV transformers if you want to go that route.
Microwatt
Wed May 18 2011, 01:39AM
can we make the oscillator go into flyback mode?
blufire
Tue Jun 07 2011, 05:11PM
blufire Registered Member #3935 Joined: Tue Jun 07 2011, 05:07PM
Don't the CW multiplier/Marx generator methods sidestep the secondary winding insulation problems, as the higher voltage is only seen after the multiplier stage?
Dr. ISOTOP
Tue Jun 07 2011, 06:05PM
Yes. This is why people use multipliers on commercial HV supplies instead of trying to wind a secondary for 50KV.
