  • Guests: 43
ZVS flyback driver help?
alf
Fri Jun 03 2011, 11:03AM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hi,
a few questions about the zvs circuit,
is the input to the circuit ac or dc? and if its ac, is it mains frequency ac?
and this is a resonant circuit, does the inductor define the resonance frequency?
or is it the transformer that does that?
and must i wind my own primary, and not use the existing one?
and have you found any better circuits,
interms of efficiency, highest output voltage and current etc?
maybe a 555 timer circuit,
thanks for reading that lol, Alf.
Ash Small
Fri Jun 03 2011, 11:33AM
The input is DC. nominally 12V. Higher voltages can be used, the zener diodes limit voltage to 12V on the drive side, but if you want to use a higher voltage it is best to have a separate 12V supply for the drive side. (circuits are out there if you use the search function or google)
The centre-tapped primary of the transfoermer and the capacitor determine the frequency. I think the frequency changes under load, due to the inductance of the primary changing, but I'm not certain about this.
You need to wind your own centre tapped primary, usually 5 + 5 turns, if I remember correctly.
There are more efficient circuits, etc. The main advantage of the Mazilli ZVS circuit is it's simplicity.
(And welcome to the forum)
