  • Guests: 40
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Uses for nixie tubes
magnet18
Thu Jun 02 2011, 03:38AM Print
Alright, I seem to have mastered the nixie clock, or at least become competent enough to build one using 40xx chips that actually works.
So, this raises the question, what's cooler?
Grenadier used some in his x-ray machine, which became something so complex I lost track of what's going on, but it's a good application.
Anyone ever built something using these?
Anyone have any cool ideas?
I'm thinking maybe integrating them into my fusor project or a plasma speaker, but I'm not exactly sure how just yet.
Anyway, this is a general discussion thread for nixies, so have at.
Inducktion
Thu Jun 02 2011, 03:58AM
You could make a multimeter...you could make anything with numbers, essentially. Retrofit your microwave to look old, your oven, your egg timer, whatever, anything that uses numbers nixies can be used.
Ash Small
Thu Jun 02 2011, 11:18AM
magnet18 wrote ...
.Anyone have any cool ideas?
If you are building a fusor there is no end of possibilities.
Readouts for vacuum guages, readouts for neutron scintillators, readouts for grid voltage and current, readouts for deuterium feed rates.............
magnet18
Thu Jun 02 2011, 11:42AM
Yea, I was thinking I could cover the fusor in the things, but since I'll probably only ever use it like twice, I was trying to think of something that gets used daily, or at least weekly...
Avalanche
Thu Jun 02 2011, 11:51AM
I have a single nixie tube somewhere, and I always planned to use it to make a rotating nixie clock (a POV display using a single nixie instead of a row of LEDs). I can't remember if I've seen someone else do it online, but I never actually got around to it.
Ash Small
Thu Jun 02 2011, 12:08PM
magnet18 wrote ...
Vacuum systems have lots of other uses....different grid configurations/voltages/polarities,etc enable all kinds of plasma processing/ion beam stuff to be undertaken.
Once you've achieved fusion I'm sure you'll move onto other things.....vacuum tube manufacture, vacuum induction casting, etc, etc.........
ConKbot of Doom
Thu Jun 02 2011, 12:32PM
A DMM stuffed in an AVO-8 or similar looking case with a nixie display would look slick if you could find a non-functional one for not too expensive on ebay or similar.
Forty
Thu Jun 02 2011, 12:40PM
make a giant nixie calculator
radiotech
Thu Jun 02 2011, 06:46PM
Single Nixie combination lock.
Mode of operation.
Press the button.
Nixie flashes at a regular cadence random 0-9.
The daycode is a three or four digit sequence, flashed
once per initiation, with initiation sequence locked out for
n seconds if fail to solve,
When you see the daycode, on the fourth numeral flashed
following it. press button to enter.
Nicko
Thu Jun 02 2011, 08:48PM
Join the Google neonixie-l group - in the last 10 years or so pretty much anything that can be done with nixies has been.
Some folk are now making their own, but not on a commercial scale.
Current discussions centre of the astonishingly rare CD47s & F9020AAs - a single CD47 sold on eBay this week for nearly USD 1000. F9020AAs go for north of USD 350 normally.
Things to note - nixies don't like shock/vibration, so bike speedos don't last long. Also, they don't switch very fast as they have significant internal capacitance - a POV display has been done (more than once) as have all the other suggestions above.
Personally, I like novel ways of telling the time - a good friend who is a graphics designer type, does lovely things with nixies in novels way:
Link2 - my personal favourite is the "approximate clock". I'm lucky to have several of John's designs in my collection.
