  • Guests: 22
Terrorhertz (16)
10/01 Avalanche (42)
10/02 Carl A. Willis (45)
10/03 TwirlyWhirly555 (33)
superposition of two sound waves
Wed Jun 01 2011, 03:06AM Print
If I send 10khz signal to an object and I get a 9khz signal back, would the superposition yield a 1khz signal? Can I simulate this by adding or subtracting the two sine waves to give me the third?
Any references on this with respect to obtaining a doppler shifted frequency?
I found this, but wanted something more formal
magnet18
Wed Jun 01 2011, 03:18AM
IamSmooth wrote ...
If I send 10khz signal to an object and I get a 9khz signal back, would the convolution yield a 1khz signal? Can I simulate this by adding or subtracting the two sine waves to give me the third?
I think so, try graphing a 10Hz and a 9Hz wave on top of each other and seeing what it looks like. Spice might prove useful for adding them together for you.
I got no references.
Myke
Wed Jun 01 2011, 04:35AM
Wouldn't you get a beat freq of 1kHz? It's like 10kHz modulated by 1kHz in a sense (difference of the freqs being 9kHz again). Mixers can add and subtract frequencies like this.
Wed Jun 01 2011, 07:07AM
Adding and subtraction of waves can't generate any new frequencies, because they are linear processes. If you add two sine waves of almost the same frequency, you get what looks like a difference frequency in the envelope, but it doesn't exist: if you do a spectrum analysis you just see the two frequencies.
To generate sum and difference frequencies you must multiply the two waves together, or some other non-linear operation. This is how "mixers" in radio systems work.
If you listen to a superposition of two sine waves, you can hear the difference frequency, as anyone knows who tried tuning a guitar. But this is because your ears are non-linear detectors. They generate it themselves.
radiotech
Wed Jun 01 2011, 07:19AM
Sound from a source (ie loudspeaker) has a Q or directivity
in acoustic terms.
A diagram of your experiment would help, where the
transducers are especially.
Two different sound sources in one common space seldom
add coherently and the determination of the resultant pressure
level can be calculated with a graph.
As to the beat of two tones in space, as the reference said,
they dont, however for practical purposes even with two sources
of similar Q , but opposite direction,they will both be present in a common space , even if they are tens of decibels different in level.
Quoting Helmholtz.
...that many different trains of waves can be propagated at the same time through the same mass of air , without mutual disturbance..
