  • Guests: 34
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
TwirlyWhirly555 (33)
10/03 TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
Where can I buy some 735 nm LEDs?
jpsmith123
Fri May 27 2011, 11:37PM Print
Does anyone know where I can get 735nm LEDs?
Fri May 27 2011, 11:50PM
jpsmith123 wrote ...
Marubeni America Corporation
3945 Freedom Circle, Suite 1000, Santa Clara, CA 95054
408-330-0650 (Ext. 323), 408-330-0655 (Fax), **link**
jpsmith123
Sat May 28 2011, 02:22AM
Unfortunately you apparently have to buy a minimum of 50 pieces from them @ $2.58 each.
I can't believe that LEDs in this wavelength range (730 nm should be ok too) are so hard to find, and so expensive when you do find them.
Pinky's Brain
Sat May 28 2011, 04:31AM
Roithner sells them in smaller volume at higher prices.
Sat May 28 2011, 04:17PM
Why do you need such a strange wavelength?
Also surely it would be simpler to find some off the shelf cheap IR LEDs and sort through them with a spectrometer to locate some 735s?
jpsmith123
Sat May 28 2011, 09:29PM
My first choice would be 670 nm or 680 nm, but I can't find much of anything at these wavelengths either. And the few that I've found seem to be very low power.
I want to make an LED array radiating at one of the wavelengths that seem to be effective for photobiostimulation effects, e.g., Link2
Pinky's Brain
Sun May 29 2011, 12:51AM
Mouser has 5 Watt for 7.35 Euro :
PS. is the wavelength really important? Plain old water can filter out all the deep infrared, and heat lamps are very cheap per Watt.
Sun May 29 2011, 02:07PM
We had this discussion on #hvcomm a while back, the upshot is that 400nm light is bioeffective but 445 is not.
There is a second band at around 780nm which seems to accelerate healing but this is far infrared.
It also seems to treat retinal damage according to a DARPA paper.
NASA have done a lot of work with using LED (not laser) sources as a way to treat injuries in microgravity where healing is substantially slowed, and some papers published.
-A
jpsmith123
Sun May 29 2011, 03:46PM
I think what I'm going to do is to go with some readily available 660 nm diodes.
Sun May 29 2011, 03:53PM
Also, to maximise efficiency the array NEEDS to be temperature regulated.
Old laptops are an excellent source of passive heat pumps, just remove the HSF assembly, clean up and attach LED array with self adhesive thermal pad.
i found a source over here, Arcadia has it in stock and for only £5 there is enough material for several arrays.
-A
