  • Guests: 112
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Looking for an ignitron datasheet
Thu May 26 2011, 11:53AM Print
I've found a few of these ignitrons but wasn't able to find any information on them.
1306410666 639 FT1630 004
Does anyone have the data sheet or any information on these. I'm planning to use them as a switch in pulse capacitor bank.
Thu May 26 2011, 01:05PM
Va = 20 kV. Vtrig = 1.5 kV.
Here is a link to a NASA Technical Note of May 1965, which looks right up your street:
CHARACTERISTICS OF A 5-KILOJOULE, IGNITRON-SWITCHED, FAST-CAPACITOR BANK
By Charles J. Michels and Fred F. Terdan
You'll notice that the NASA invention uses a General Electric ignitron type GL 7703, whilst yours is the Westinghouse version, WL 7703.
Interestingly, in true 4HV style, the NASA team are determined to over-volt their ignitrons at 30 kV, 10 kV above
the manufacturers Vmax 20 kV rating
Thu May 26 2011, 01:20PM
Thanks a lot. Already have dedicated triggering psu's for them and about 12 of these devices. Seems they are of use for my application.
Sun May 29 2011, 03:51PM
Found out a few of them are destroyed can hear the parts of the rattling. Doesn't sound like just the mercury in the others frown
Sun May 29 2011, 06:36PM
Oh that's a shame, Dalus!
But you could still go ahead and make your own triggered gaps now that you've started to think about it.
radiotech
Sun May 29 2011, 07:21PM
7703- Pulse igniton-Peak Fwd 20 kV.Peak Anode 100 kA. Mean
Anode 0.75 A. Ampere-second per pulse 10 A.s..
Sun May 29 2011, 10:10PM
Luckily I do have 8 ignitrons that are in good shape. They measure fine and are able to strike an arc when triggered. Using them would be less of a hassle then building my own triggered sparkgap. I'll be using them at a relatively low voltage for normal sparkgaps. Only way to make a proper triggered gap is to use multiple segments which greatly adds to the design complexity.
Thinking of them they are amazing devices especially for the time that they where used in. Would like to put them to good use again. Seems a shame not to use them.
radiotech
Mon May 30 2011, 01:41AM
Here is a scan of my datasheet on the 7703
1306719710 2463 FT116433 7703
Mon May 30 2011, 09:43AM
Thanks radiotech. Some of the datasheet books where lost in the lab. Luckily others do know where to find them smile
Mon May 30 2011, 11:15AM
This paper describes the important procedure for conditioning an ignitron that has been out of use for some time:
