  • Guests: 38
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Class D amplifier help
Inducktion
Wed May 25 2011, 03:26AM Print
I recently constructed a circuit using the skeleton Link2 of this schematic as a guide. I used the same IC, except, with a 2.2k resistor alone, and a .0015 uF capacitor instead of the values shown. I also changed the audio cap to a 4.7 uF capacitor. I also removed the 4 UF diodes, and removed any associated GDT parts including the zener diodes. The square wave I measured coming out was 333 kHZ.
As for the gate drive transformer, I did away with it and replaced it with a FAN7382, an easy to use high-low side IC. I used a 30 ohm resistor, a Schottky diode, and a 10 uF 16 V tantalum capacitor for all of the components shown on the datasheet. i used 10 ohm gate resistors, (from output to gate) and 10k gate to source resistors.
I used a 12 volt regulator for all the logic needs, and used TO-220 mosfets for the half bridge. I left out the 10,000 uF capacitors, (I'm not sure if they're needed or not?) and used a low pass filter consisting of two .1 uF caps in parallel in parallel with the speaker, and a 30 ohm resistor in series with the speaker.
Scoping around, I noticed the wave going to the speaker was a triangle wave. It worked, for the most part, but, the issue that arose was audio quality and loudness. Adding more voltage just distorted the sound even more, and drowned out any music. The actual sound quality at a certain volume is actually pretty decent; but, it's also really quiet.
Is there any way to increase the loudness and quality of the music coming out? Is there anything I possibly left out, or need to change? I appreciate the help a lot!
Wed May 25 2011, 08:17AM
The modulation is completely wrong for a Class-D amp. You've got bipolar PWM, it should be unipolar.
Inducktion
Wed May 25 2011, 08:39PM
Steve McConner wrote ...
Bipolar?
You mean complementary waves coming out of the 3525?
Sat May 28 2011, 06:33AM
Bipolar PWM has three voltage levels: plus, minus and 0. the waveform goes +,0,-,0, etc. The plus and minus on-times are equal, and the control voltage modulates them equally. The result is a waveform symmetric about zero, with no DC component, so it passes through GDTs and SMPS transformers. When rectified in the secondary rectifier, the negative pulses are made positive, so it reverts to regular PWM, and the supply's output voltage ends up proportional to the control voltage.
But since the waveform has no DC component, connecting it straight to a speaker will do nothing. That's why you need unipolar PWM, which just goes +,0,+,0, etc, with the control voltage modulating the ratio of + to 0. This won't pass through a GDT, so you have to use an IR21xx type driver chip.
Inducktion
Sat May 28 2011, 06:12PM
Does that mean a 555 timer based version would work?
Sat May 28 2011, 08:07PM
Yep, probably.
Also, I think there's a way you can connect the 3525's two outputs together to get unipolar PWM, or maybe I'm getting confused with the TL494.
Inducktion
Sat May 28 2011, 11:07PM
I think it is unipolar PWM, but when you connect the two it becomes bipolar.
Sun May 29 2011, 07:43AM
Well, whatever PWM you have just now, you need the other kind. The kind that works with an audio modulated flyback is wrong for a Class-D amp.
