  • Guests: 49
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Fixing laser diodes
Sun May 22 2011, 01:44PM Print
I just revived two totally dead (20 ohms in both directions) 405 burner diodes using a technique based on reverse pulsed bias.
Used 9V lithium (maybe important, there seems to be a current limit on these) applied in reverse with very short pulse cycle.
Seems that it "blows out" the short if the pulse is large and narrow enough, leading to a working laser at reduced power as long as the bond wires also don't blow during this treatment.
Unfortunately one diode failed shortly after when trying to increase power from LED-like levels by more zapping.
I would recommend the use of a relatively low voltage say 1.5V at several hundred mA for about 0.5us as this would reduce the chances of a blown bond wire.
The way to tell if it is working is to measure the reverse current. If the short is gone then the current will drop sharply down to 10mA or so with 100 ohm series resistor in the reverse direction from >100mA.
Just to prove that this isn't a joke, I include beam shots and power data from the diode which survived.
Used a PS3 diode as the beam power sensor, and got the following.
14.31 mA on diode at 40mA power in
>20mA on diode at 60mA power in
Used an attenuator consisting of polarising sheet in beam path.
0.59mA at 40mA in
0.88mA at 59mA in
0.98mA at 67mA in
Offset 0.12mA (quiescent)
Managed to get some voltage readings on the diode...
4.46V at 43.4mA
4.51V at 45.1mA
4.66V at 53.5mA
4.69V at 54.7mA
4.75V at 58.5mA
4.83V at 60.4mA
4.88V at 65.2mA
4.91V at 68.4mA
4.93V at 70.5mA
Additional observations during this process.
The diode will get HOT! I think this is probably normal, as all the energy is being dissipated within the shorted area.
I also noticed that signs of a potentially recoverable diode are that it will read slightly different currents in forward and reverse bias, a permanently fried diode will not do this and read more like 3 ohms or less.
It appears that this effect is unique to GaN devices, I have never noticed anything like this with any other laser.
I also had a PS3 diode once with a big hole in the beam profile which recovered some power when I zapped it with 60mA short pulses.
-A
Forty
Sun May 22 2011, 05:52PM
Gotta love fixing stuff by breaking it more.
