  • Guests: 41
Dielectric breakdown as function of ...
LD LANGER
Thu May 19 2011, 09:14PM Print
LD LANGER Registered Member #3824 Joined: Sun Apr 10 2011, 08:29PM
Hello, I am interested in finding out if anyone knows anything about this off hand (Which is more than likely):
I know that dielectric breakdown as a function of voltage follows the Paschen curve. It seems intuitive that dielectric breakdown should also be a function of available current as well. As far as I can tell, I have found no information on this subject past the Paschen curve. I've spent a couple hours searching google as well as the ieee xplore for any journals or publications, but found nothing (although there is a ton of data regarding breakdown in the realm of um and nm).
Does anyone know anything regarding dielectric breakdown as a function of current and frequency (not properties of the dielectric itself)?
Regards,
Daniel
Thu May 19 2011, 10:55PM
Haefely AG have a paper in their Scientific Documents download section:
Influence of the source impedance on the breakdown behaviour of air spark-gaps
I have tried to open this link to check it for you, but was unable to do so,
so there may be a problem with it.
magnet18
Fri May 20 2011, 12:29AM
Proud Mary wrote ...
I opened it no problem, it's the right link.
LD LANGER
Fri May 20 2011, 01:43AM
Excellent, thanks for the info!
