  • Guests: 56
Erasing a CD with high voltage (Video)
Xray
Fri May 20 2011, 05:30PM Print
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
While scanning through some of the more interesting videos on wimp.com, I came across this one: Link2 It's interesting because of how the high voltage discharge appears to be turning the CD from translucent to transparent as the data apparently gets wiped off the disc. Is this a hoax?
Avi
Fri May 20 2011, 05:47PM
No its not as hoax, i replicated it, and made a big mess. but it wont work on a dvd because the foil in inside and a separate label; on top
magnet18
Fri May 20 2011, 08:35PM
It doesn't really erase the data per se, it just rips the foil backing off the cd.
It's probably unreadable.
Fulmen
Fri May 20 2011, 10:14PM
Fulmen Registered Member #3883 Joined: Fri May 13 2011, 06:30PM
I concur. This will blast the reflective foil backing from the disk, rendering it unreadable. Whether or not the dye gets damaged or not I don't know, but I guess it at least will be effective for anything but highly sensitive data.
Not that it matters though, if you really need to erase a CD I can think of several methods that are both easier and more effective. Non as cool, fun and impressive though.
magnet18
Sat May 21 2011, 12:24AM
Microwave would do a much better job at eliminating datas.
