  • Guests: 225
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Charging a battery
ZakWolf
Thu May 19 2011, 03:47AM Print
I am making a mini iPod amp and i bought a 12v 1.3Ah battery to power it, i also bought a 12v 1 amp trickle charger. My question is Could someone use the amp as the battery is charging? The only amp draws about a milliamp or two.
Side note: the smile button doesn't work with Google chrome any fixes?
Mattski
Thu May 19 2011, 04:34AM
Yes that should be fine, it will just divert some/all of the charging current to the amplifier. But unless it's a really tiny headphone amplifier I think it must draw more than a milliamp or two.
ZakWolf
Thu May 19 2011, 04:48AM
That may be true, I set my multimeter to measure current and it was sent on A it looked like this 0.18A so is that 18 milliamps or .1 milliamp. I have only used this setting twice. :|
radiotech
Thu May 19 2011, 04:59AM
The way you typed that 0.18 A would be 180 milliamps. or
roughly a fifth of an amp. At 12 volts that would be about 2 watts.
Best be very sure with instruments, always.
Another thing about digital meters: Always test the reading in
your mind to see if it is reasonable.
Once your eyes pick up the reading, a logical system light
years ahead of that electronic device takes over to make
sense of the numbers.
ZakWolf
Thu May 19 2011, 05:48AM
Thank you radiotech, so how would I figure out how long a 1.3Ah battery would last?
Thu May 19 2011, 06:47AM
1.3Ah means it can (in theory) deliver 1.3A for one hour before running flat. In practice it will be less: the battery makers specify it over 10 hours, over which period it would deliver 130mA. Faster discharges are less efficient.
So if it supplies 130mA for 10 hours, how long can it supply 180? You do the math. tongue
PS: These SLA batteries last longer if you keep them topped up and don't run them completely flat often. Leaving one lying around discharged for weeks is the kiss of death.
PPS: A 1 amp charger seems a bit too powerful for this tiny battery. It will try to charge it in 2 hours and then go on to wreck it. I charge the larger 4Ah ones at 0.5A.
ZakWolf
Thu May 19 2011, 02:42PM
Thanks, the charger that comes with it is a 500ma charger and the one i want to get is a 1 Amp trickle charger
