  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Connecting fiber optic cable to LED's.
Hazel1919
Wed May 18 2011, 01:51PM Print
Hazel1919 Registered Member #1376 Joined: Wed Mar 05 2008, 08:31AM
Hello,
There are two questions regarding fiber optic cable that I would like to ask about.
1 - I would like to know how you connect your fiber optic cables to led light sources. In particular, a 1mm OD cable to a conventional LED.
As far as I can see, you must drill a small hole in the plastic housing of the LED and then tape, or heat shrink, the entire led and cable.
But the drilling of the hole causes the plastic to frost up.
Also,
2 - How would you cut fiber optic cable?
Many, many thanks in advance.
Wed May 18 2011, 03:16PM
I buy the optic transmitters / receivers from new, they have all the mounting hardware in itself.
I just cut the cable with a fresh hobby blade, its more than suffecient for our single colour low frequency use, even professional cutters are the same, just with a aligned blade to get a 90 degree cut. We no longer use sand paper, polish etc when cutting optics in the industry.
Ash Small
Wed May 18 2011, 04:33PM
Plasma wrote ...
I've no idea how successful it would be, but what about using a 'hot wire' to make the hole?
(Heated 1mm tungsten TIG electrode, maybe? or maybe 1mm stainless welding wire/rod)
ConKbot of Doom
Wed May 18 2011, 04:40PM
Mads Barnkob wrote ...
And the professional ones cleave the glass fiber to give it a clean edge that doesnt need to be polished. As far as the hole frosting when drilled, it should be countered by however you attach your fiber (I.E. index matching gel, epoxy, etc...)
If I wanted to stick a plastic fiber into a plastic domed LED, I'd use UV cure adhesive to fasten it. I.E. norland optical adhesive, and as long as there arent air bubbles, the NOA should fill in any imperfections in the end of the fiber or LED dome plastic.
Plus obviously with a 1mm plastic fiber, then you arent using this for communications, except maybe TOSLINK, and most likely just illumination?
Wed May 18 2011, 04:46PM
Interesting.. I would advise using UV cure epoxy for this, as it seems to be index matched to the fibre.
DO *NOT* USE "Superglue" or it will not work, I learned this the hard way.
As for cleaving the fibres, purchase a pair of toenail clippers and this should work fine.
(found this tip in EPE)
-A
Wed May 18 2011, 05:23PM
when you say "normal LEDs" do you mean the T 1-3/4 size ones?
Hazel1919
Wed May 18 2011, 08:36PM
Thank you very much for your prompt replies!
I am seriously considering using the UV cure optic epoxy. Thank your for that suggestion.
Ash Small - I did consider this, and tried something similar, the only trouble was that the metal would cool off before any considerable melting of the plastic.
Patrick - Any LED that has a plastic dome in which the fiber optic cable can be embedded.
The clipper idea is very practical.
Again, many thanks.
Pinky's Brain
Wed May 18 2011, 10:07PM
Damn, never realised simple fiber optic transmitters/receivers were so expensive ... cheapest for decent bandwidth transmitter and receiver (100 MHz) is ~4$ a piece. Seems steep for a trivial bit of silicon and some plastic.
Thu May 19 2011, 12:50AM
Is anyone here familiar with the optical power and dispersion budgets in cheap plastic-fiber links?
It would not surprise me if 100 Mbps operation (much less 100 MHz, or the 1 Gbps in development) needs lasers and/or limited-NA coupling, and nontrivial Rx electronics.
1305765530 2099 FT115833 Pof
The Tx and Rx ends probably have coupling lenses, in additional to the mechanical details to align and retain fiber connectors. Imagine the optical waveform pictured above, scaled to a 10 microampere detector current at 100 Mbps. (the two waveforms in picture are offset to hide the fiber prop delay, which is about 75 bit times.)
I have specified and qualified multi-gigabit transceivers, used with single- and multi-mode quartz fiber. Tx and Rx optical subassemblies include hermetic TO-cans, glass lenses, and alignment of fiber ends within microns in 3 dimensions. Tx and Rx electronics each include multiple die with different technologies, and a whole transceiver costs more than $50 in volume, even today.
Pinky's Brain
Thu May 19 2011, 03:50AM
That's 150 meter ... what I'm talking about is for a little shorter range, with no integrated electronics apart from the led/photodiode and a relatively unsophisticated plastic screw cap to hold the fiber against a plastic lens.
They say the receiver can handle analog video at 70 MHz.
