  • Guests: 34
Will (38)
Arlecchino (41)
07/24 Jim_VE7UV (65)
07/26 Jorrit (39)
07/26 e.m.c.2 (45)
Scientists plan to sail robot boat on methane lake of Saturn's moon Titan
Mon May 16 2011, 08:07AM Print
Open University team led by Professor John Zarnecki hopes Nasa will back project to explore chances of life beneath Titan's surface
Robin McKie, Science Editor
The Observer
Sunday 15 May 2011
Space engineers are planning to build the first extraterrestrial boat. They want to launch the craft towards Titan – Saturn's largest moon – and parachute it on to the Ligeia Mare, a sea of methane and ethane on its surface.
The robot ship would sail around this extraterrestrial sea for several months, exploring its coastline and measuring the winds and waves that sweep its surface. "Waves on Titan's seas will be far larger, but much slower, than on earthly oceans, according to our calculations," said Professor John Zarnecki, of the Open University. "That suggests Titan is the best spot in the solar system for surfing. The only trouble is that the temperature there is -180C (-290F). Either way you look at it, it is clear the place is pretty cool."
The mission to Titan – the only moon in the solar system with a thick atmosphere, of nitrogen and methane – would be the first exploration of a sea beyond Earth and could provide evidence about the possible existence of complex organic chemicals, the precursors of life.
"Methane is a gas on Earth, but because Titan is so cold it acts as a liquid there," added Zarnecki, who is working with US scientists on the construction of the Titan boat probe. "It exists as a liquid, a gas and a solid, just like water on Earth, depending on conditions in a particular area. Methane also cycles between Titan's surface and its atmosphere, just as water does on Earth. It drives the weather there."
Ultraviolet radiation from the Sun reacts with this methane, causing it to form complex hydrocarbons that slowly fall back to the surface. In short, it rains petrochemicals on Titan. Rivers of the stuff wash down valleys and form lakes and seas. Over the past seven years, these petrochemical seas have been mapped by US robot spaceship Cassini. In addition, Cassini deployed a smaller probe, called Huygens – built by the European Space Agency – which landed on Titan in 2005. Many of the instruments for that craft were built by Zarnecki and his Open University team. This experience led to a request for them to join the Titan Mare Explorer, or TiME, project that is being funded by Nasa and led by Ellen Stofan, a researcher with the science organisation Proxemy Research.
According to her plans, the TiME probe would be fired at Titan on a billion-mile journey across the solar system. Once it enters the moon's thick atmosphere the craft would parachute down towards the surface and then drop into the 300-mile-wide Ligeia Mare. It would then spend several months afloat on an oily sea taking measurements of waves, chemicals and other variables.
"The probe's main instrument will be a mass spectrometer, which will tell us exactly what the lake is made of. However, we also want to do things like depth-sounding," said Stofan. The instruments would be powered by a small nuclear generator, because Titan is so distant from the Sun that solar panels cannot be used to provide power for detectors or transmitters.
Titan is also thought to have an ocean of water deep underground. Complex organic chemicals, created on its surface, could be seeping down through fissures so that primitive lifeforms could have evolved in relatively warm waters beneath the moon's surface. Hence scientists' interest in studying Titan.
The TiME probe was originally selected as one of 28 missions that Nasa was considering as future projects. Twenty-five of these candidate missions have now been rejected, and the Titan mission now has only two other competitors for the £300m funding that will be needed for its development and launch. The other two are a seismic monitoring station for Mars and a comet-hopping probe. Detailed plans for all three are now being worked out by scientists, and the winner will be chosen after a review in 2012. In the case of TiME, launch would be in 2016, with the ship arriving seven years later.
"When the proposal for the TiME mission went in, it had a one-in-28 chance of success," said Zarnecki. "Now Nasa have shortlisted it, it has a one-in-three chance – that's getting serious. I didn't think I had a chance of returning to Titan in my career. Now that's all changed."
Mon May 16 2011, 08:13AM
we will see, NASA has been on the wrong side of budget concerns before. constalation was cancelled. we Americans have spent to much all ready, NASA is on everyones list to cut funding for.
Mon May 16 2011, 08:35AM
Patrick wrote ...
That's what I thought, Patrick - but my, doesn't the idea capture the imagination! smile
Inducktion
Mon May 16 2011, 01:07PM
Proud Mary wrote ...
Patrick wrote ...
It sure is amazing.... But what is the point of it? Just exploration?
Mon May 16 2011, 02:45PM
Patrick wrote ...
Oh, this is the stuff dreams are made of.
But why stop at building a measly robot boat. They should send Lieutenant Colonel Bill Kilgore, and his platoon, in full cryogenic outfit. We want a full report about the properties of that surf!
wink Finn
magnet18
Mon May 16 2011, 03:19PM
The search for life in our solar syslem continues.
