  • Guests: 51
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
3 Stage Coilgun Rifle
currentkills91
Tue May 10 2011, 08:21AM Print
Hey everyone!
I've started working on this project about a week ago, and wanted to start posting about it. So here goes...
It's going to be a fully portable, 3 stage coilgun. I'm hoping to achieve a speed of 60+ meters per second with this gun. When i'm done with it I want it to be able to shoot through almost anything practical. The gun itself is going to be a rifle like design, being as small and compact as possible.
Here are some of the design specs...
Coils:
1st Stage - 8 layers, 16 gauge wire, 40mm long
2nd Stage - 8 layers, 16 gauge wire, 40mm long
3rd Stage - 6 layers, 16 gauge wire, 40mm long
Charging: ZVS Flyback Driver (uzzors2k's design)
Powered by 22.2 volt 4000 mAh li-po battery
Output power >100 watts
Capacitor Banks:
1st Stage - 4x560uF for 2240uF
2nd Stage - 3x560uF for 1680uF
3rd Stage - 3x560uF for 1680uF
(all caps are 450v)
Stored Electrical Energy:
1st Stage - 207 joules
2nd Stage - 155 joules
3rd Stage - 155 joules
Total ~ 517 joules
Switching:
1st, 2nd, and 3rd Stages - 4x40 amp triacs in parallel (1680 amp pulse rating) (BTA41-600BRG)
2nd and 3rd stages triggered by optical sensors and lm393 comparator chip.
Clamping diodes:
1st, 2nd, and 3rd Stages - 6x3 amp diodes in parallel (1200 amp pulse rating) (1N5408)
Projectile:
6mm diameter, 35mm long steel rod, slightly sharpened
Pictures: Flickr
Videos: Youtube
Triggering Setup
Charger Progress
First Stage
Charger Rough Draft
Charger Rough Draft Part 2
1st Stage Speed Test
Turkey9
Tue May 10 2011, 09:15PM
No video! Oh no!
currentkills91
Wed May 11 2011, 03:34AM
Yeah i know...for some reason youtube wont let me upload the video...it keeps failing...and i forgot to take that bit out of there x.x ill do that right now! and ill update it when i get the video uploaded....
currentkills91
Mon May 23 2011, 06:56PM
I now have some videos uploaded up top there ^ and i've ordered pretty much everything except the capacitors and the triacs. I'll add more videos as i go...
currentkills91
Fri Jun 03 2011, 04:44PM
UPDATE: added more videos
Turkey9
Sat Jun 04 2011, 07:18AM
Looking good! I just have a couple questions:
First, the optical sensors on the first stage are there to trigger the second stage, correct? If so I assume all your coils will be pushed up against each other as close as possible.
Second, I may have missed it but it seems like that brass barrel isn't slotted. You probably want to do that before you spend a lot of time on your coils as that will provide a noticeable increase in power. Or at least it did in mine.
Also, are you going to actively monitor your cap charge and cut the power when charge is reached? Or are you just going to vary the input voltage to the point that it can't charge past the max ratings.
Speaking of max ratings, you mentioned something about 550v caps in your videos I think? Is that correct?
All in all nice job. I love the point to point construction of your break beam sensors. Keep up the good work!
currentkills91
Tue Jun 07 2011, 11:32PM
Well thank you very much for the kind words!!
First, yes, they're there to trigger the second stage, and the goal is to move them around till they are perfectly aligned.
Second, i'm just working on test coils right now. Once I build the final coils they will be slotted and much neater than they currently are.
Third, I plan on using the regulator circuitry provided with uzzors2k's flyback capacitor charger, because i'll be using an 18.5v battery, which will give almost a 700v output (description says 14.8v but i've changed my mind)
Fourth, i'll be using 450v caps for the final design, if I said anything about 550v caps then I must of really been out of it O.o
Once again thanks for your kind words!!
