  • Guests: 64
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Four Stage Inductance Coilgun
Turkey9
Tue Dec 07 2010, 06:57AM Print
This thread will follow the build of my new coilgun. It's going to have the following specs:
4 Stage, coils are around 36 uH 14awg. Four layers, 32 mm long
4 x 320 uF 1200V polypropylene caps
4 x 1200V 3.5kA pulse stud SCRs
CCPS to charge everything up quite fast hopefully.
Brass projectile with wall thickness equal to skin depth
Capacitive sensing of the projectile
PVC coil form
The gun will be an inductance type. Each coil is designed as to have around 3kA peak staying within the SCRs' limits. When the projectile reaches a certain point past the coil, the coil will fire inducing eddy currents and pushing the projectile forwards. I'm using a capacative system to sense where the projectile is. I'll use this to alter the position of the projectile when the coil fires to figure out best efficiency. The four coils will be wound on a pvc coil form. The form itself is actually two pieces bolted together as the bore length was too long to have a single piece.
As far as the capacitive sensing, this is my setup. I have aluminum foil wrapped under the coil to be the first plate. There is a second section of foil immediately following the coil. The projectile will bridge the gap between them and increase the capacitance of the circuit. I'm thinking that I'll have an oscillator circuit that will change frequency as the capacitance changes. I'll read the frequency with a micro and use that to switch the coils. Does this sound feasible? We'll see what happens.
Below are the pictures of the first section of coil form, the capacitor plates, and the first coil wound on.
1291703726 1451 FT1630 1206102233a 328733
1291703726 1451 FT1630 1206102254a 313907
1291703726 1451 FT1630 1206102316a 329543
Machined the other part of the barrel today. It bolts together with four M3 machine screws and everything lines up great! The projectile falls through the barrel fine but it you plug one end it slows way down due to the good fit.
I also found that if I run a 12V 7kHz signal through the capacitive sensor, the signal that gets through goes from 1.8V to 3.6V! That should be plenty to trigger on and also allow some room to detect position.
I think I'll have a small daughterboard above each of the coils that will have the signal generator and amplifier. I think I'll have a dual op amp setup so that the output of another sensor is subtracted from the output of the current sensor. In other words, since all sensors are identical and the projectile can only be in one sensor at a time, there will always be two waveforms being compared, one with the projectile and one without. If this makes no sense I can answer any questions.
Below is a quick paint diagram showing the schematic and physical layout of the capacitive sensor.
1291970298 1451 FT1630 Diagram
And then the new barrel section attached and also with a closeup.
1291969641 1451 FT1630 1210100114a 372225
1291969641 1451 FT1630 1210100114b 287644
Here is the schematic I worked up for the capacitive sensors. It uses a differential amp for each section fed into the ADC of a PIC16F690. The connector going into the amps will have one feed from the section being triggered and one feed from a different section for use as a baseline measurement. I'll generate the frequency train with the PIC. The PIC 16F690 will then monitor the charge on the capacitors and all other functions. I think I'll have a slave micro running the cap charger and possible magazine power supply. Would there be any benefit in using a dedicated charger for each capacitor? The total power input would be the same but would the charging time increase? Below is the schematic.
EDIT** I have now changed the schematics, see below for the updated design.
1292826309 1451 FT1630 Coilgun Sensor Schematic
I wound the rest of the coils tonight. I'm home now for a bit and have access to a good camera so the pics should be better quality smile .
1292834424 1451 FT1630 P1040863
1292834424 1451 FT1630 P1040865
SCHEMATICS AND BOARD
Here is the updated circuitry. I am now using a PIC16F887 just because I have it on hand. I'm using a module system similar to that of the Arduino/Shield deal. Each board will plug into the main control board with exception of the charging board witch will be mounted on the heat sink. I have also added connections on the control board for an 16X2 line LCD display.
The connectors provide a 5V, 12V, and gnd power connection. They also have all of the unused in/outs of the micro. This will allow any other daughter boards to be connected if the need arises, which most likely will!
CCPS charging board
1293526377 1451 FT1630 Ccps
CCPS charging schematic
1293526377 1451 FT1630 Ccps Schem
Control Board
1293526377 1451 FT1630 Control
Control Schematic
1293526377 1451 FT1630 Control Schem
Differential Amp Board
1293526377 1451 FT1630 Differential Amp
Differential Amp Schematic
1293526377 1451 FT1630 Differential Amp Schem
SCR Trigger Board
1293526377 1451 FT1630 Trigger
SCR Trigger Schematic
1293526377 1451 FT1630 Trigger Schem
Turkey9
Tue Dec 28 2010, 09:09AM
Updated and changed the Schematics.
ZakWolf
Tue Dec 28 2010, 09:19AM
why is the wire so thick? I thought you get a stronger magnetic field with more wire.
Turkey9
Tue Dec 28 2010, 10:15AM
You do, but you also get a stronger magnetic field with more current, That wire will have close to 3,000 amps flowing through it so it needs to be thick.
Dr. ISOTOP
Tue Dec 28 2010, 10:24PM
What lovely coils you have :) I look forward to seeing this run.
Turkey9
Mon Jan 10 2011, 04:14AM
I have now gone from design of the boards to experimentation. I have etched the CCPS board and partially populated it. I'm using a PIC12F617 to generate the pulse chain and monitor the cap's voltage. As I etched the board before changing the part I'm not making use of the PWM module of the chip. Instead, I've just written a program that bit bangs a serial input from the main control micro and then runs a loop of fixed number of pulses. After the loop, the cap voltage is checked and another loop of pulses is run if needed. The serial interface lets the micros know what voltage the capacitors are to be charged to and when they are full. Below are some pics of the heat sink that will be used and the CCPS board with everything but the high side passive components. Also, a couple waveforms in there too.
1294633167 1451 FT1630 Dscn0056
1294633225 1451 FT1630 Dscn0057
1294633243 1451 FT1630 Dscn0068
1294633264 1451 FT1630 Dscn0069
The Inductor to insure proper oscillations of the tank circuit.
1294633283 1451 FT1630 Dscn0071
1294633308 1451 FT1630 Dscn0079
1294633330 1451 FT1630 Dscn0081
Dr. H.
Mon Jan 10 2011, 08:09AM
Good day Turkey9 what a beautifull setup you have there :)
But aren't you creating a shorted turn under the coils with the wrapped alu foil ?
Cheers
Turkey9
Mon Jan 10 2011, 11:56PM
Thanks!
It would seem so but the foil tape actually has an insulating layer; the adhesive. This means that when the edges overlap they are not actually electrically connected. I don't know if it shorted on the edges but I suppose I'll find out when I start testing!
Turkey9
Mon Jan 24 2011, 08:46PM
I've started working on the brains of the operation. This is my first time working with an LCD and also programming in C. I've found a great enclosure for the electronics! It was an old computer controlled CD changer. It has a separate SMPS board in the back with line filtering and 5V and 12V lines. It will house the digital electronics and the inverter. The caps will be mounted on top with the coilgun and scr's on top of those. I've found a lot of 1/2" and 3/8" plexi so most of the mechanical structure will be of that.
The coilgun will be controlled through an 8 button switch panel. The LCD will allow the cap charge, rate of fire, and number of shots to be altered through a menu setup. The main control board will handle all of this apart from actual charging which is handled by the SLR micro. The control micro sends out a set of commands and the SLR one charges the caps to the set voltage and returns a done command to the control. I've already taken care of the serial transmit functions in the programs. Next I'm going to breadboard the capacitive sensors to make sure they work.
And of course the pictures:
1295902522 1451 FT0 Dscn0082
The Full case
1295902619 1451 FT107064 Dscn0084
1295902661 1451 FT107064 Dscn0086
1295902715 1451 FT107064 Dscn0100
LCD in the dark. You can kinda see the board under it.
1295902742 1451 FT107064 Dscn0103
An over all of the control bread board. The input board can be seen on the right. Each input has an individual 47K pull-up resistor.
Turkey9
Wed Jun 08 2011, 07:07AM
I haven't been working on this project in a while, but decided that I need to get back to it. So first thing I do is hook up a quick scr + trigger+ all-that-other-stuff to test it out. Charge up to a measly 160V and fire. I hear a click but nothing else. So I hook up a doubler and charge up to 350V and try again. This time a click and the projectile moves only a tiny fraction of an inch. Apparently it doesn't work how I thought it would. After playing around in FEMM and doing some thinking, I realized that no matter what, due to Lorentz Law, the force will always be pushing in on the projectile and not from the back like I thought. This is because for the most part, the flux lines will be traveling radially down the projectile. For the gun to work, the flux lines would have to be traveling from the center of the projectile out to the coil so that the force vector is correct. After a lot of thought, I cam up with an idea. I would run an iron rod down the middle of the barrel with the projectile slid over the top. This would mean that the field lines would hopefully be in the correct position at the ends of the coils. When simulating this, it seems like it will work wonderfully! The projectile has a 45N force acting on it at the highest current, the same that an iron projectile would experience! Below are a couple screen shots with this new set up. The first one is with the first coil energized and the second one is with the next coil. I found the highest force to be achieved with the center of the projectile about at the end of the coil. With this set up, the projectile actually has a large force on it anywhere past the center position of the coil.
EDIT: It seems like the number I provided for force should only be used as a qualitative estimate. That number was with a planar calculation with a depth of 1mm. With a depth of 10mm (1/2 the diameter of my coils) the force is multiplied by ten. When I changed the simulation to axisymetric, the total force was 139N which seems much more realistic to me!
The first stage:
1307517271 1451 FT1630 Icg First Coil
The second stage:
1307515972 1451 FT1630 Icg Second Coil
I have got the communication working between the main micro and the CCPS control micro. It was a pain figuring out how to do it with the very limited feature set that the 12f pic has. None the less, it receives and interprets commands and can respond to them.
I have also decided to do away with the capacitive sensor and go with traditional optical sensors as they are very reliable. I have drilled all the holes and have the parts already in my bin, do now I can devote most of the work to get the thing actually firing!
Thanks!
