  • Guests: 38
Bill G (65)
Overclocked (38)
Edi (32)
09/21 Bill G (65)
09/21 Overclocked (38)
09/21 Edi (32)
DIY Heatsink
Chip Fixes
Thu May 05 2011, 08:24PM Print
Yay, it's finished!
1304627049 3781 FT0 Sink 1
1304627049 3781 FT0 Sink 2
1304627049 3781 FT0 Sink 3
1304627049 3781 FT0 Sink 4
1304627049 3781 FT0 Sink 5
EDIT: This probably should have gone on the project thread, oh well
It was made in a day with stuff I had so it's definitey not perfect. If you have anything I could add to make it better please leave a comment
Inducktion
Thu May 05 2011, 08:52PM
Camp Badger wrote ...
Yay, it's finished!
How'd you manage to make that? it looks pretty good.
Chip Fixes
Thu May 05 2011, 08:58PM
I needed a good heatsink for my mosfets that I use for my plasma speaker because they were cheap and get hot quite, fast, even at 12v. I'm hoping to be able to put 50v through the flyback without the fets blowing so I looked at what I had and went from there. The best part is that I can take it all apart if I need to, Nothing's permanent. There is also a pump for the cooling system that I made but it's not shown.
magnet18
Thu May 05 2011, 09:41PM
I'm interested in how you made the pump
any idea how many gph / lpm it is?
Chip Fixes
Thu May 05 2011, 11:39PM
no idea, i just used instructables and lots of hot glue :D
magnet18
Fri May 06 2011, 12:58AM
Ah, nice and simple, I like.
Chip Fixes
Thu May 12 2011, 09:55PM
Oh hey, i got a bunch of xbox heatsinks and fans from a friend, are these equipped for water cooling? if so, how? One end of the copper pipe is closed...
1305237321 3781 FT114958 Heatsink
1305237321 3781 FT114958 Heatsink2
Ash Small
Thu May 12 2011, 10:14PM
No, it isn't 'equipped' for water cooling. The copper pipe just transfers heat to the upper part of the fins.
I'll be posting details of my air cooled heatsinks soon (once I've finished the first of my current batch).
My opinion is that unless you are prepared to use refrigeration or cryo-technology, air cooling is better than liquid cooling (well, certainly simpler)
Chip Fixes
Thu May 12 2011, 10:28PM
ok thanks, I'm looking forward to your post
Ash Small
Thu May 12 2011, 10:36PM
The exception to my above post would be when you immerse the components directly in, for example, oil, eg transformers, etc.
(Hope this makes sense)
