  • Guests: 32
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Sonic lasers
Thu May 05 2011, 06:12PM Print
Heh, I have a bunch of these motors.
Wonder if pancake motors would work too?
-A
Coronafix
Fri May 06 2011, 06:08AM
Wow, that was interesting. I found the same thing once in a completely different apparatus.
I made a hammered dulcimer with 12 sets of strings, 3 strings per set strung across a bridge adjusted for the fifth.
While messing around with the tuning of it once, I set all the strings to one note. The thing began to hum with the slightest tap. It would get louder too, like it was singing with more energy than I had put into it.
Kinda scared me actually, I thought it was going to break and quickly detuned it.
Edit. Just had thought, if you had a number of electromagnetic resonant coils, could it make an 'elctromagnetic laser'? (To test the mathematics.)
Where the motors are vibrating through the plate, instead the resonators could vibrate through....what does EM travel through?
the vacuum I guess, that's in the equation as the medium of transmission (permittivity and permiability of free space).
A vacuum waveguide would then be necessary. Wow. again.
Nicko
Fri May 06 2011, 03:16PM
I wonder if this effect is analogous to the phenomenon observed by clock makers over the centuries whereby if two or more pendulum clocks (e.g. Grandfather Clocks) are placed in the same room (on the same floor without mechanical isolation), their ticking/swing will eventually synchronise? (and in some cases, all the clocks stop!)
Fri May 06 2011, 03:51PM
Yes, I believe all of these things are forms of entrainment Link2 (discovered by Huygens in 1666)
Entrainment was used in electronics for syncing oscillators and frequency division, before the PLL was invented.
Coronafix: Entrainment needs non-linearities to work. It won't work with the coils because they are linear. You'll just get frequency splitting instead. The closest thing to your electromagnetic laser is a Tesla coil.
If you want an electronic demonstration, make a whole load of neon lamp flashers all running off the same poorly decoupled supply, they should synchronise just like Nicko's (or Huygens') clocks.
In a laser, the quantum effects are what provide the non-linearity. (An excited atom has a threshold: it needs a bash of a certain size to stimulate its decay.)
Fri May 06 2011, 04:12PM
Nicko wrote ...
Chaotic oscillators were all the rage in the 1990s - you couldn't go anywhere without meeting someone trying to nudge two wretched circuits into synchrony.
Googling chaotic oscillator synchronization will exhume a trove of them.
Fri May 06 2011, 05:35PM
ROFL!
Sort of like the flashing firefly effect methinks.
Wonder why you can't get solar powered fireflies which you can place anywhere, sort of like an LED throwie.
-A
#include "Patent_this_and_Burn_in_Grethor.h"
Fri May 06 2011, 05:58PM
Proud Mary and Steve McConnor raise valid points, Ive seen people try to claim analogus functions like a "sound laser" or "electrical beaming" or "mechanical sympathetic organization". But many of these claims are fairly unsupported, and the math in some cases seems to contradict the given explanation.
Some of these devices are interesting as a idea, academic pursuit, but there is no need to claim revolutionary explanations or over hype their significance.
EDIT: the LRAD is one of the few devices that I really like, is practical and sort of like a laser for sound, in so far as the constructive destructive wave interference and so on.
